Текущее время: 28 апр 2024, 03:14
 Заголовок сообщения: sony (mbx-226) not trun on
СообщениеДобавлено: 16 дек 2013, 00:22
Заблокирован
Hi , the machine does not start when i press the power button , I got the green light led and device turn on but after 2 seconds turn off again this cycle for ever
mbx- 226 model: vpccw21fx
Things I do
1 - PCB services and connections
2 - BIOS update with interchangeable iC
3 - Ec Update with interchangeable iC
4 - Replace the I / O
5 - check the battery voltage and the power button OK
6 - resold graphics chip
7 - resold charging IC
8 - test new processor
9 - Change the ram
10 - no cut or damage PCB
I really mix up, what else, sometimes boot well but after 5 min not boot again and green power for 2 second and ........ , and possibly / /
Thank you all in advance please
 Заголовок сообщения: Re: sony (mbx-226) not trun on
СообщениеДобавлено: 16 дек 2013, 19:43
LPC activity?
СообщениеДобавлено: 16 дек 2013, 22:11
Заблокирован
thank for your answer
whats your mean ? LAD3, LAD2, LAD1, LAD0, CLK, RST, FRAME, +3v & GND. ?????.
i not wired that yet ? but on PCI-E no result
this device restart in 2 second ...
СообщениеДобавлено: 17 дек 2013, 00:28
chek 3.3v on swich power and
the pin 5 bios is not to group and usb 5v not to gerand
must 3.3v on batty pin if this not may be the ic charg problem
when put buttry you see bottry light?
check with the full battry and try to power
check 3.3v and 5v must is not gerund !!!!!
may be ic 3.3 and 5 must be replace
and chek the bios some of the sony when bios crash all of voltaj is down
check bios
may be south brigh must be replace
ask the customer how to do and your notebook is not work
is used usb port???? is work in iternet a lot????
СообщениеДобавлено: 17 дек 2013, 01:09
Заблокирован
check bios
سلام اقا آرش
1-3.3v on power key and pin 5 bios is
2-usb no shorted
3-battry have 3.3v
4-i test with full battery no result
5-3.3 not grounded with 5v
6-i changed bios ic and firmware but no result
7-south is ok
8-customer just say happen unexpected
СообщениеДобавлено: 18 дек 2013, 00:46
Заблокирован
today when i get the
PQ23 out from board mainboard work without restart but when i change that no result and restart again i thing all problem is from cpu PWM circuit but how i check ?
СообщениеДобавлено: 19 дек 2013, 00:01
Заблокирован
the trouble in PWM circuits some fet SIR428 i need to change ..can i change fet with another fet without match number like pc mainboard ?????
( in pc mainboard every fet response when i change without match ...
В этой теме нет новых непрочитанных сообщений. dell n4030 (dj1) not trun on
в форуме Dell
nasser_pczone
15 янв 2015, 15:28
and555 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony vpccw21fx (MBX-226) Not Booting
в форуме Sony
FRD
04 фев 2015, 23:41
FRD Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell (La-8241p) trun off after 2 second
в форуме Dell
nasser_pczone
20 сен 2015, 23:43
nasser_pczone Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell E5510 (Fonseca 15 mb 09226-1) Trun Off after 3 second
в форуме Dell
nasser_pczone
30 апр 2016, 18:35
В этой теме нет новых непрочитанных сообщений. Sony (mbx-226 rev1.1 1p-009b501-8011 m9a0) как вырезать дискретную видеокарту n11p-lp1-a3
в форуме Sony
Schacal
13
3735
11 май 2015, 11:20
