Текущее время: 24 апр 2024, 21:27
Заголовок сообщения: Re: sony (mbx-235) gray screen Добавлено: 24 янв 2014, 11:56 |
The 4 pin is very important.
nasser_pczone
Заголовок сообщения: Re: sony (mbx-235) gray screen Добавлено: 24 янв 2014, 14:15 |
Зарегистрирован: 08 ноя 2013, 16:20 Наличности на руках: -40.89
Сообщения: 73 Откуда: iran Заблокирован
hi thanks for fast responding i jumper pin 4 from LVDS to led cable connector directly but problem still was i mixed up whats this gray screen ??? system boot OK on CRT monitor but on self led gary screen ??? please help me ?? Posted after 5 minutes 41 second:for more info : i change led with new one but no result
Заголовок сообщения: Re: sony (mbx-235) gray screen Добавлено: 24 янв 2014, 14:59 |
Do You do this? RsM писал(а): need to measure resistance on 8 wires on LCD connecror on mother board. 4 pairs=8wires With screen connected.
nasser_pczone
Заголовок сообщения: Re: sony (mbx-235) gray screen Добавлено: 24 янв 2014, 16:26 |
MSF113 писал(а): Do You do this? RsM писал(а): need to measure resistance on 8 wires on LCD connecror on mother board. 4 pairs=8wires With screen connected. hi no i not test.. because i not understand how i must do - please help me this solution step by step and clearly . near the led connector no resistor is to check ? who resistor your mean ?? thanks
nasser_pczone
Заголовок сообщения: Re: sony (mbx-235) gray screen Добавлено: 25 янв 2014, 00:35 |
hi yes i know the resistor is component on the electric board DC/AC board who reduce voltage and resistance is value for this reduce voltage in Ohm unit i understand what you told me i must check the ohm on 8 wire ?? its that right ?? if yes- what value is true?? very thanks mr RSM
