Текущее время: 23 апр 2024, 19:38
 Заголовок сообщения: sony vpcee34fx (DA0NE7MB6D0) It does not power On
СообщениеДобавлено: 02 фев 2015, 15:28
Hello i Have a sony vpcee34fx [DA0NE7MB6D0 REV:D] it does not power on i chek the 3.3 v on the power sw and bios and after that program the bios but it does not power on again what is the next step to solve the problem thanks. :ne_vi_del:
 Заголовок сообщения: Re: sony vpcee34fx (DA0NE7MB6D0) It does not power On
СообщениеДобавлено: 02 фев 2015, 15:55
Попробуй так.
In English:
0. When BIOS & EC-firmware 100% are working
1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope)
2. When ACIN = 3.3V
3. When LID_SW# = 3.3V
4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V
5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT#
6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
Under these conditions EC should give command for start.
(с) Ciber SLasH
Ремонт ноутбуков
Санкт-Петербург +79313406112
Ессентуки +79283151170
СообщениеДобавлено: 02 фев 2015, 18:45
I check the voltages again I found that IO release 3.3v RVCC-ON and i check it on the pin3[EN] pu22[oz8116][RVCC 1.1v]
but pu22 can not release 1.1 RVCC i change pu22 but it does not work
this mean the main is ok until power step 2 but PM_SLP_S3 [step 3] does not do the job for more information please check the scheam
Thanks-its realy force
 ! MSF113 писал(а):
Use more "," and "." in post.
Too hard to understand you.
СообщениеДобавлено: 03 фев 2015, 13:40
What would you need to do to locate the fault measurements on EC pins (U13):
Before pressing the On button pins 4, 10, 95
While pressing the On button pins 108, 15
After pressing the On button pins 102, 17, 96, 106
This is assuming that oscillates Y2, Y7.
Check.
Ремонт ноутбуков
 Заголовок сообщения: Re: sony vpcee34fx (DA0NE7MB6D0) It does not power On  [РЕШЕНО]
СообщениеДобавлено: 04 фев 2015, 16:50
Excuse me for my bad english, I learned it new.
Thanks orbit. The problem was about south bridge. s3
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Q5WV1 rev.2.0 (LA-7912P) does not light any LED panel, not power
eletmoraes
21 апр 2016, 11:32
andromedax Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. sony sve141mfxw (sve) does not power on
в форуме Sony
ahkh_72
06 янв 2015, 13:26
ahkh_72 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus n53sv (asus ) it does not power on
ahkh_72
21 фев 2015, 17:14
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Vaio VGN-FZ11M (MBX-165 MS90) Does not power on
в форуме Sony
zibi1998
10 мар 2015, 20:01
zibi1998 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 15-n051su (Quanta U93 DA0U93MB6D0) does not power on...
latitude
26 янв 2017, 23:49
latitude Перейти к последнему сообщению
