LPC mbx 224 https://vlab.su/viewtopic.php?f=55&t=5801 |
sebuncle [ 12 фев 2012, 20:08 ] | |
Заголовок сообщения: | LPC mbx 224 |
hi , i wan't to connect LPC on MBX 224 this motherbaord have connector cn15 i take this part of schématic on mbx165 Can i use it for connect LPC on mbx224 ? many thanks |
Ciber SLasH [ 12 фев 2012, 23:23 ] | |
Заголовок сообщения: | Re: LPC mbx 224 |
sebuncle писал(а): Can i use it for connect LPC on mbx224 ? Try this. |
sebuncle [ 13 фев 2012, 01:19 ] | |
i connect to cn15 , i have code post 00 and led clk flashes. |
sebuncle [ 04 мар 2012, 20:55 ] | |
hi , i connect other debug card (the last has failed) i have this code B2 what does it mean ? many thanks |
sebuncle [ 03 апр 2012, 16:03 ] | |
hi , i change ati 216-0774007 , screen comes , laptop works well , but 20second after power , the fan go quickly everytimes. where is the thermal sensor ? best regards |
MSF113 [ 03 апр 2012, 16:28 ] | |
Check the thermal pads on video and north brige, check settings in BIOS setup (FAN control). Check CPU and video temperatures in OS (AIDA - CPU, Firmark -video for example). Reflash BIOS firmware. |
sebuncle [ 03 апр 2012, 16:57 ] | |
hi , i check thermal pad , i have change cpu , full system fan , the northbridge have no cooling. i check temperature with aida64 cpu core 1 & 2 are to 37°c , and GPU is to 34°c there's nothing to change fan in bios i flash bios but no change. best regards |
MSF113 [ 03 апр 2012, 17:05 ] | |
I don't know this model. How many flash ROM's installed on? Main or main + kbc BIOS? You needed full rom image from good mobo. |
sebuncle [ 03 апр 2012, 17:12 ] | |
there are bios and KBC , i have flash all. |
MSF113 [ 03 апр 2012, 17:16 ] | |
sebuncle писал(а): temperature with aida64 cpu core 1 & 2 are to 37°c AIDA64 give the core1 core2 and processor temperatures. what is the temperature of the processor? 35-40? |
sebuncle [ 03 апр 2012, 17:26 ] | |
MSF113 писал(а): sebuncle писал(а): temperature with aida64 cpu core 1 & 2 are to 37°c AIDA64 give the core1 core2 and processor temperatures. what is the temperature of the processor? 35-40? yes |
MSF113 [ 03 апр 2012, 18:02 ] | |
Bridge is 82HM55? |
sebuncle [ 03 апр 2012, 18:33 ] | |
yes BD82hm55 |
MSF113 [ 03 апр 2012, 18:39 ] | |
The power management fan control etc. works jointly kbc and BD82HM55. BD82HM55 has own flash memory with this data. It's possible point of trouble. It can only be replaced by a new one, not used. |
sebuncle [ 03 апр 2012, 19:22 ] | |
ok , i'll buy a new and try to change it . i'll tell you . best regards |
Ciber SLasH [ 03 апр 2012, 20:44 ] | |
Try this Bios & EC dump "not tested" |
MSF113 [ 04 апр 2012, 08:15 ] | |
sebuncle писал(а): ok , i'll buy a new and try to change it . Wow, not so fast. It possible point of trouble. Try firmware from Ciber SLasH first. |
sebuncle [ 04 апр 2012, 14:18 ] | |
Ciber SLasH писал(а): Try this Bios & EC dump "not tested" hi, my motherboard is a M960 , this bios is for M961 . i have tried , but motherboard don't start with this KBC (no led no power) , if i flash with other kbc it start but it's the same fan go quickly |
sebuncle [ 19 апр 2012, 17:50 ] | |
hi , i have find anything if i install UpdTW64 extract from pack original bios , it flash under windows , after i have error message " Failed to open the IO/Memory driver" but after few seconds fan go slowly and works normaly (2400 rpm) if i restart laptop the fan go quickly...i have to setup UpdTW64 again... Can you tell me why ? |
lamo [ 25 апр 2012, 18:45 ] | |
it's possible, that you have some troubles with ME-region in bios rom. if you have "clear" bios rom from sony web-site, you should flash it. if not, and you're using some "downloaded" dumps from other laptops, this trick won't work. launch intel utility(don't ask me, which one, i don't know where to find it) to reflash this region correctly. |
Ilyas [ 26 апр 2012, 08:15 ] | |
Tell me your model of notebook. It looks like VPCEB... |
sebuncle [ 26 апр 2012, 15:27 ] | |
hi, it's a VPCEB1E1E |
Ilyas [ 27 апр 2012, 07:55 ] | |
Its your bios and ec dump |
sebuncle [ 01 май 2012, 00:56 ] | |
Ilyas писал(а): Its your bios and ec dump i cant flash bios i have already error with programmer. i have change BD82HM55 , nothing change. |
mostafalive [ 03 июл 2012, 03:11 ] | |
try this bios and kbc working |
