Sony Vaio (SVE14A15(board code MBX-273)) auto shut down https://vlab.su/viewtopic.php?f=55&t=60152 |
tujuhkalitujuh [ 17 апр 2017, 08:27 ] | |
Заголовок сообщения: | Sony Vaio (SVE14A15(board code MBX-273)) auto shut down |
Hello guys, I got the SVE14A15 with Discrete ATi GPU. with MBX-273 printed on the mainboard. The previous problem was the GPU Chip pad is corrosion then I decided to put off the GPU Chip. After that the laptop always running with the Fan always on full speed RPM and then auto shutdown within +- 60 second. I found that the problem is in the ME Region. Please help me with the Clear ME Region. Thank you very much. |
and555 [ 20 апр 2017, 16:40 ] | |
Заголовок сообщения: | Re: Sony Vaio (SVE14A15(board code MBX-273)) auto shut down [РЕШЕНО] |
I don't think it's ME problem, it's overheat problem, I usually add a copper plate between the GPU to the heatsink. But, if You want clear ME, try below: Вложение: MBX-273_ClearME(v8.1.0.1248).bin.7z
