I have a Fujitsu Siemens Amilo Pi 1505 no power I attached the file is no voltage on the mosfet. what should I do thank you very much
RsM
Заголовок сообщения: Re: Fujitsu Siemens Amilo Pi 1505
Добавлено: 11 мар 2013, 13:48
Модератор
Зарегистрирован: 12 окт 2012, 21:53 Наличности на руках: 5,124.83 Сообщения: 8221 Откуда: Сыктывкар
Check signal NB_FPVDDEN (p.10). It must be 3,3V
robertevoula
sorry for the delay the voltage on the capacitor C24 is 0v not 3.3v I not manage to find the resistance R 174 on the motherboard
RsM
Добавлено: 11 мар 2013, 16:04
Модератор
if you can't who can? Search.
robertevoula
le signal NB_FPVDDEN (p.10)=0V ---------- Добавлено спустя 1 час 12 минут 5 секунд: ---------- All voltage are correct only at this point 0V should i change north bridge?
RsM
Добавлено: 11 мар 2013, 22:26
Модератор
You should to write a platform, describe your problem, history.
robertevoula
i have Fujitsu Siemens Amilo Pi 1505 theres no power on (10) NB_FPVDDEN=0v i joind an attached file i need to know what must i do ? change North-Bridge? because 3.3v come from N-B thank u very mutch for your help.
RsM
Добавлено: 13 мар 2013, 17:21
Модератор
