Fujitsu Siemens Amilo Pi 1505 https://vlab.su/viewtopic.php?f=57&t=11933 |
robertevoula [ 11 мар 2013, 13:41 ] | |
Заголовок сообщения: | Fujitsu Siemens Amilo Pi 1505 |
I have a Fujitsu Siemens Amilo Pi 1505 no power I attached the file is no voltage on the mosfet. what should I do thank you very much |
RsM [ 11 мар 2013, 13:48 ] | |
Заголовок сообщения: | Re: Fujitsu Siemens Amilo Pi 1505 |
Check signal NB_FPVDDEN (p.10). It must be 3,3V |
robertevoula [ 11 мар 2013, 15:00 ] | |
Вложение: schema.jpg sorry for the delay the voltage on the capacitor C24 is 0v not 3.3v I not manage to find the resistance R 174 on the motherboard |
RsM [ 11 мар 2013, 16:04 ] | |
if you can't who can? Search. |
robertevoula [ 11 мар 2013, 17:24 ] | |
le signal NB_FPVDDEN (p.10)=0V ---------- Добавлено спустя 1 час 12 минут 5 секунд: ---------- All voltage are correct only at this point 0V should i change north bridge? |
RsM [ 11 мар 2013, 22:26 ] | |
You should to write a platform, describe your problem, history. |
robertevoula [ 13 мар 2013, 14:50 ] | |
Вложение: schema.jpg i have Fujitsu Siemens Amilo Pi 1505 theres no power on (10) NB_FPVDDEN=0v i joind an attached file i need to know what must i do ? change North-Bridge? because 3.3v come from N-B thank u very mutch for your help. |
RsM [ 13 мар 2013, 17:21 ] | |
Необходимые условия старта |
