Текущее время: 25 апр 2024, 13:07
chulat
Заголовок сообщения: Re: AH531 (DAFH5AMB8F0) No power Добавлено: 08 янв 2014, 17:14 |
Сообщения: 956 Откуда: Дербент
What on S5_ON? check check their: 0. When BIOS & EC-firmware 100% are working 1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope) 2. When ACIN = 3.3V 3. When LID_SW# = 3.3V 4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V 5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT# 6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
P.zonouz
Заголовок сообщения: Re: AH531 (DAFH5AMB8F0) No power Добавлено: 08 янв 2014, 17:38 |
Зарегистрирован: 01 июн 2013, 20:03 Наличности на руках: 18.07
chulat писал(а): What on S5_ON? 5. When by pressing of the power button the signal ON/OFFBTN# falls to zero
ON/OFFBTN# has no voltage to drop!!! I must be 3.3v till power switch pressed... but no voltage produced.
_________________ Don't give up without the fight.
