Esprimo V5535 (Inventec Z17M) Not stabile work after gpu driver install https://vlab.su/viewtopic.php?f=57&t=19995 |
notemaster [ 18 мар 2014, 12:24 ] | |
Заголовок сообщения: | Esprimo V5535 (Inventec Z17M) Not stabile work after gpu driver install |
Firsty after instalation gpu driver laptop it shut down (even before windows start) and it's the same all the time. I repaced SIS M672 for a new bga chip, but it still the same. Next bga to replace is SIS 307LV, but i don't have new chip (only used on other motherboard, but working). And my question - if someone have the same problem and solved this by replacement SIS 307LV? I wanna know it first because I'm not sure if it is a solution for this problem... |
