Текущее время: 26 апр 2024, 19:23
 Заголовок сообщения: Amilo XI2528 dead LVDS
СообщениеДобавлено: 08 сен 2011, 16:03
Board Uniwill P75/55
Detachable Nvidia 8600 card.
As title say,but with external monitor works fine.
Internal display completly dead,not even 3.3V power.
During POST if I insist few times on Fn+F10 (switch between internal-external monitor) I get internal display powered.
Now there is 3.3V on LVDS connector CCFL start,brightness adjust works too.
But on display I see only this.
Is not my photo but is identical.
Measured some voltage on LVDS .
External monitor active,internal inactive.
V EDID and EDID signals are 3.3V ,LVDS data pins have each 0,2V there is no 3.3V for LCD power.
That seems fine.
External monitor inactive,internal active.
V EDID and EDID signals and LCD power are 3.3V That seems fine too.
But on LVDS data pins 8 to 18 (except 10,13,16 which are GND) there is 2.1V and rest of them are all 0V. That's bad.
Since in inactive state I get 0.2V and in active state 0V I think is not related to cracked balls under GPU for LVDS pins.
Some advice are welcome.
 Заголовок сообщения: Re: Amilo XI2528 dead LVDS
СообщениеДобавлено: 08 сен 2011, 22:29
Connect the other matrix. Blow air 300°С on the chip 10sec.
СообщениеДобавлено: 08 сен 2011, 23:11
By matrix you say LCD display?
Already tried ,same result.
Like I said this is not my photo,I found it on the net.But simptom are identical.
Same image,identical,show on internal display.
I'll try to reflow video card.
СообщениеДобавлено: 23 сен 2011, 07:55
Заблокирован
Heat up the chip the hair dryer 280-300 With 10-Sec and look, most likely, the chip under replacement.....
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Amilo Pa2548 (PTT50) Нужен биос Amilo Pa2548 под видео G84-53-A2
в форуме Fujitsu-Siemens
Oleg_k
02 фев 2015, 10:47
Oleg_k Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Amilo Li3710 (Amilo Li3710) перестают работать кнопки тачпада и мышки
elektron
04 янв 2017, 13:41
elektron Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. a1278 (j30 820-3115-b) dead after water damage
в форуме Apple
vortex252
17 май 2014, 12:23
5781848 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 5740g (JV50-CP 09285-1M 48.4GD01.01M) Acer Aspire 5740G dead / not starting at all.
anuragis1
01 июл 2014, 07:49
В этой теме нет новых непрочитанных сообщений. Vaio PCG21314w (M9F1) Laptop dead no boot.
в форуме Sony
montarbo
30 ноя 2014, 00:13
montarbo Перейти к последнему сообщению
