S710 (DA0FJ6MB8F0 REV F ) When plug adopter auto turn on https://vlab.su/viewtopic.php?f=57&t=63960 |
rajeshkumar [ 24 июл 2017, 09:54 ] | |
Заголовок сообщения: | S710 (DA0FJ6MB8F0 REV F ) When plug adopter auto turn on |
Hello friend I am received s710 fujitsu DA0FJ6MB8F0 REV F which facing problem when plug power adopter its auto turn on. Any one have solution reply |
Lex66 [ 24 июл 2017, 10:32 ] | |
Заголовок сообщения: | Re: S710 (DA0FJ6MB8F0 REV F ) When plug adopter auto turn on |
May be RTC battery is bad or absent ? After auto-power-on laptop is work fine? |
rajeshkumar [ 24 июл 2017, 10:46 ] | |
rtc working fine and battery perfect |
Lex66 [ 25 июл 2017, 14:59 ] | |
Check the LAN port, if it work, try to program bios. If it does not metter - check the PCH |
rajeshkumar [ 27 июл 2017, 10:13 ] | |
Lex66 писал(а): If it does not metter - check the PCH in these condition pch not responsible for these |
Lex66 [ 27 июл 2017, 12:27 ] | |
PCH is not ONE big device - this is many devices in one box. Is you flash the bios and EC? |
rajeshkumar [ 28 июл 2017, 09:11 ] | |
Lex66 писал(а): PCH is not ONE big device - this is many devices in one box. Is you flash the bios and EC? Flash both bios ec and main try different site to download and flash bios. but status same |
bgiplmukesh [ 29 июл 2017, 19:02 ] | |
rajeshkumar писал(а): Lex66 писал(а): PCH is not ONE big device - this is many devices in one box. Is you flash the bios and EC? Flash both bios ec and main try different site to download and flash bios. but status same try to change kbc |
Lex66 [ 06 авг 2017, 15:41 ] | |
did you check the LAN? |
Radio2865 [ 06 авг 2017, 16:26 ] | |
may be its becomes causer EC |
rajeshkumar [ 10 авг 2017, 13:29 ] | |
Заголовок сообщения: | Re: S710 (DA0FJ6MB8F0 REV F ) When plug adopter auto turn on [РЕШЕНО] |
Radio2865 писал(а): may be its becomes causer EC but ec is progamable and ec not available Posted after 1 minute 18 seconds: i am does not find any solution sooo close these topic thankss for your valuable reply and time |
