Текущее время: 20 май 2024, 23:53
 Заголовок сообщения: Lenovo Thinkpad L530 (Intel) No Power
СообщениеДобавлено: 06 фев 2020, 07:04
Lenovo Thinkpad L530 No Power Problem. Connect with adapter and adapter light goes out. 19V line is short. I do not have schematic of this model. So i remove PR4002 Resistor (Fig-1) and connect with DC Power Supply to find short (hot component). Found shorted Capacitor near CPU and Replace with good one. But when i connect with adapter, it short again. Found Other capacitor near CPU short again. So i check Capacitor (Near CPU) with Multimeter and found 19V. When i connect Adapter (or) Power Supply, 19v is also here in CPU Supply Volt line (Fig-2). I think CPU Supply Volt may be 1V or nearly. But in this laptop 19v is there in CPU Supply Volt Line. I don't know Why? Please help me to find this kind of short.
Fig-1
https://drive.google.com/open?id=16UWvg ... TPJ1DD28pR
Fig-2
https://drive.google.com/open?id=12eOWh ... RTBV9gHiyf
Lenovo Thinkpad L530 (A)
https://drive.google.com/open?id=13hkrq ... VDW56yoiEJ
Lenovo Thinkpad L530 (B)
https://drive.google.com/open?id=18Q1-l ... 1uGeYUqjzl
 Заголовок сообщения: Re: Lenovo Thinkpad L530 (Intel) No Power
СообщениеДобавлено: 06 фев 2020, 08:07
check upper mosfet`s in cpu power (pu4301 pu4303 ?).
СообщениеДобавлено: 07 фев 2020, 19:50
First of all, thanks for your help. I found bad mosfet (PU4301). But i do not have this type of mosfet. So i tried to replace with some N-Channel mosfet by wire connection. Now laptop is power on but no display. CPU Core voltage is ok (about 1.1V). But a few minutes run replaced mosfet is so hot and wire connection is loose. Any short remain on motherboard? Or need to replace same type of mosfet.
https://drive.google.com/open?id=1-j0dT ... a7vN8yiSxY
https://drive.google.com/open?id=1OemCV ... _DJgwvT1AB
В этой теме нет новых непрочитанных сообщений. Куплю материнку Lenovo Thinkpad L530
в форуме Куплю | Buy
fox2trot
20 ноя 2015, 15:00
fox2trot Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo ThinkPad L530 (?) Не загружается
toweroff
26 дек 2015, 15:59
toweroff Перейти к последнему сообщению
toweroff
21 июн 2016, 09:42
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ThinkPad L530 (Wistron LBF-1 11270-4) стартует со второго включения
Leo_vrn
4346
11 май 2017, 14:40
Leo_vrn Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ThinkPad L530 (Wistron LBF-1 11270-4) стартует со второго раза
wadim
23 июл 2018, 00:59
wadim Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], ivan_p и гости: 17
