Текущее время: 29 мар 2024, 14:11
andromedax
Заголовок сообщения: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 14 апр 2020, 15:19 |
Сообщения: 262 Откуда: Alicante, Spain
Lenovo Yoga 500-14IBD LT41 Wistron 14217-1 Hi, this laptop have missing a voltage from power up sequence. The 1D05V_M step is present only in in page 99 and 100 in schematic, but seems that there are no components connected to it. It is the seven step in the power up sequence, and the PCH_RSMRST# is 2 step after it. PCH_RSMRST# are reseting the PCH, (PCH_RSMRST# is 0,0v) so nothing functions after that. Probably is a bug on the schematic. The PCH_RSMRST# diode reading is .470 so no short-circuit in it. There are some activity on bios, but a few pulses, on pin 1, and also on pin 5. (Pulses at pin 5 are below 2 volts) This low voltage at pin 5 makes me think that problem is a pch/cpu related issue. Can someone point me a in the right direction to solve the problem? Thanks. Вложение: 1D05V_M.PNG
andromedax
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 14 апр 2020, 18:46 |
IOD писал(а): Check PU4801 1D05V_PWR. No output from PU4801, activating signal, EC_PM_SLP_S3# is low level. PM_SLP_S3# never present until PCH_RSMRST# is high.
andromedax
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 15 апр 2020, 18:43 |
Цитата: If I understood correctly, PM_RSMRST # is low. Hi, these are the readings: 3d3v_pwr= 3.31v 5v_s5= 5.02v rsmrst#_kbc= 0.0v 3v_5v_pok=3.2v 3v_5v_pok#= does not exist. ¿? lid_close#=3.2v ac_in_kbc#= 0.0v ecrst#=3.2v vd_in1, vd_in2= 3.2v, 3.2v
IOD
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 15 апр 2020, 19:12 |
Зарегистрирован: 28 апр 2015, 17:33 Наличности на руках: 9,553.76
Сообщения: 4418 Откуда: Ковель
andromedax писал(а): rsmrst#_kbc= 0.0v Check Q1701.
andromedax
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 16 апр 2020, 15:10 |
IOD писал(а): Check Q1701. Q1701 replaced. Q1701 pin 1, 3, 4, 5, 6-->0.0v Q1701 pin 2-->3.2v. Diode reading pin 3--> .470
andromedax
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 16 апр 2020, 19:59 |
IOD писал(а): Check ADT_TYPE. ADT_TYPE--> 0.44 volts with a 45w charger ADT_TYPE--> 1.5 volts with lab psu and lenovo dc-jack adapter. I will tray replacing kbc. (it is coming soon)
andromedax
Заголовок сообщения: Re: Lenovo Yoga 500-14IBD ( LT41 Wistron 14217-1) Power Up Sequence question Добавлено: 27 апр 2020, 11:09 |
andromedax писал(а): I will tray replacing kbc. (it is coming soon) Sadly kbc replaced but nthing changes. PM_RSMRST# are always at low level. Цитата: PCH_RSMRST# diode reading is .470 so no short-circuit in it. Any advice?
