this turns on one out of 10 times if you keep pressing the reset button, if it turns on it works ok for hours, i did bios update and nothing changed the keyboard works ok, no water damage and the power button works if you keep pressing it to turn the laptop off everytime what could be causing this?
artell
Заголовок сообщения: Re: ideapad 320-15ast (nm-b321) turns on sometimes with the reset (Novo Button)
Добавлено: 28 июн 2020, 23:03
Зарегистрирован: 16 фев 2018, 22:52 Наличности на руках: 5.07 Сообщения: 116 Откуда: Украина
Check cable length DC + 19V. Try a shorter cable. Check the basic + 3V and + 5V for these cases.
mantza
