Lenovo 320 (NM-B242) No 19v https://vlab.su/viewtopic.php?f=58&t=108219 |
xe_d_sono [ 21 окт 2020, 20:02 ] | |
Заголовок сообщения: | Lenovo 320 (NM-B242) No 19v |
Hello, Sorry for my english. I've a Lenovo 320 (N M-B242), that input keys are open, but ACOK (BQ24780S) is 0v: 1. ACN - 20v 2. ACP - 20v 3. CMSRC - 20v 4. ACDRV - 26v 5. ACOK - 0v 6. ACDET - 2.8v (too high?!) 24. REGN - 0v Any tip? Already change the BQ24780S, Input Keys, but same result. Thanks |
IOD [ 21 окт 2020, 20:15 ] | |
Заголовок сообщения: | Re: Lenovo 320 (NM-B242) No 19v |
xe_d_sono писал(а): 6. ACDET - 2.8v (too high?!) - normal. xe_d_sono писал(а): 5. ACOK - 0v Check resistance pin 5 PU301 relatively GND.
xe_d_sono [ 21 окт 2020, 21:07 ] | |
Is note shorted, resistence is about 100ko. |
montekristo [ 21 окт 2020, 23:27 ] | |
24 пин не припаян. |
xe_d_sono [ 22 окт 2020, 00:40 ] | |
montekristo писал(а): 24 pins are not soldered. You are right, now i have 6v. I recheck all solder joints, and still no 3v on ACOK. |
montekristo [ 22 окт 2020, 01:00 ] | |
acn, acp, srn, srp ? |
xe_d_sono [ 22 окт 2020, 01:13 ] | |
montekristo писал(а): acn, acp, srn, srp? ACN - 20v ACP - 20v SRN - 0v (with battery 8v) SRP - 0v (with battery 8v) |
IOD [ 22 окт 2020, 11:56 ] | |
QE2 present on board? |
montekristo [ 22 окт 2020, 13:47 ] | |
Отсутствует 3VL, или убитый RE42. |
xe_d_sono [ 22 окт 2020, 18:48 ] | |
IOD писал(а): QE2 present on board? No montekristo писал(а): Missing 3VL, or killed RE42. 3VL don't come after all ok in BQ24780s? |
IOD [ 22 окт 2020, 19:08 ] | |
xe_d_sono писал(а): 3VL don't come after all ok in BQ24780s? Check 3VL on RE42.
xe_d_sono [ 22 окт 2020, 20:52 ] | |
I don't have 3VL on RE42. |
montekristo [ 22 окт 2020, 21:00 ] | |
А 3VL есть? Восстанавливайте соединение. |
IOD [ 22 окт 2020, 21:19 ] | |
Check +3VLP on the pin 17 PU401. |
xe_d_sono [ 22 окт 2020, 22:24 ] | |
Bingo! +3vl are shorted! And guess who gets hot? SIO ITE8586! I will get a new one programmed and try. |
xe_d_sono [ 23 окт 2020, 13:29 ] | |
All ok! Thanks |
