Hi,if anyone can help,have problem with programming MEC1653,I'am using Vertyanov programmer,can't read,write or erase the chip,boot lock protected,write protected,data write protected,if anyone can help if there is a solution,picture is in Attachment,Thank you.
Serguz05
Заголовок сообщения: Re: Lenovo ThinkPad T470p (DT473 NM-B071 Rev: 1.0) Have problem with programming MEC1653
