Текущее время: 20 май 2024, 04:30
 Заголовок сообщения: Lenovo B590 (Wistron LB59A) turns on and off constantly
СообщениеДобавлено: 08 ноя 2014, 20:47
Greetings to all. They gave me a notebook Lenovo B590 code motherboard LB59A MB 12209-1 48.4XB01.011 whose circuit diagram is Wistron LA480.
The PC is not lit at power. I replaced the fuse F3801 and the mosfet PU3801 but downstream there was a short circuit that I found to be the PU4302 FDMS3606S, but not being able to find it in Italy
I bought one that seems to be completely equivalent FDMS3616S. Now the computer charge the battery regularly and once lit displays the startup logo, is about 5 seconds sometimes makes me enter the bios, but then goes off and then power on and off almost loop. This problem does either only power supply, either with only one battery and is with both sources. After several tests and measurements I noticed that at the time when it is turned on
pin 1 of PU4302 and PU4304 I 1.7V while on pin 1 of PU4402 initially have a pulse voltage of 1.7V but then goes down to 0,46V.
It seems that turns off for heating the CPU while the CPU is in fact still cold.
Any suggestions?
Thanks in advance
 Заголовок сообщения: Re: Lenovo B590 (Wistron LA480) turns on and off constantly
СообщениеДобавлено: 11 ноя 2014, 19:45
Check all the voltages, maybe need to reprogramm BIOS flash.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 13 ноя 2014, 02:16
Thanks for the reply. From what little remains on the PC, the tensions are all there. Sometimes I can also access the bios but then immediately turns off. Maybe it was damaged the PU4201 due to short circuit of the PU4302. I'm waiting for the replacement of PU4201.
Hopefully where I could find the file of the bios of this model?
 Заголовок сообщения: Re: Lenovo B590 (Wistron LA480) turns on and off constantly  [РЕШЕНО]
СообщениеДобавлено: 22 ноя 2014, 02:06
Dear friends I wanted to share with you the resolution of the problem. The problem was the PU4201. I replaced it and the pc works now.
Thank you all for your attention.
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 02:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Msi R7 370 2g armor turns on and off 2 seconds later
TheMArcos
1544
10 май 2020, 20:16
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Hp g62-b19sl (Turns on LED power alone) Turns on LED power alone
amennone
09 фев 2018, 01:38
desertearch Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony SVE1511C5E (Quanta HK5, MBX-269 REV-F) Looping On and Off and No video on LCD
в форуме Sony
mun4o
05 мар 2015, 19:39
mun4o Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo T460s (Compal NM-A421) After 10 seconds turns off. No screen, no beeps.
derick
30 ноя 2020, 20:55
derick Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 20
