Текущее время: 20 апр 2024, 01:07
rh189
Заголовок сообщения: Re: Lenovo 3000 N500 4233-5MG bios [РЕШЕНО] Добавлено: 25 авг 2011, 12:58 |
Зарегистрирован: 20 июл 2011, 12:51 Наличности на руках: -2.95
ниже будет инструкция, а вот сам файл здесь выкладывать не буду, дай почту в личку, отправлю. еще понадобится USB-флоппик
The Hardware Maintenance Diskette is to set/view system identification and to format a hard drive.
Note: This diskette is for approved servicers and technical support people only! This diskette should never be given to an end user.
The following systems are supported: - Lenovo N500 Additional Information
This document is provided to Lenovo and our Business Partners to help sell and/or service Lenovo products. It is not to be distributed beyond that audience or used for any other purpose. Contents How to update System-Unit Serial Number How to update System Product Description How to update System MainBoard Serial Number
How to update "System-Unit Serial Number"
How to update System-Unit Serial Number in BIOS Setup
Select Item 1), Set system Serial Number, then enter MMMMTTTSSSSSSS where mmmmttt=MTM (Machine type 4 digits + Model 3 digits) sssssss=Box Serial number 7 digits.
How to update "System Product Description"
How to update System Board Serial Number in BIOS Setup
Select Item 2), Set system Product Name.
How to update "System mainboard Serial Number"
How to update System MainBoard Serial Number in BIOS Setup
Select Item 3), Set system mainboard Serial Number, then enter 11SPPPPPPPSSSSSSSSSSSS where ppppppp = Planer Part number 7 digits ssssssssssss= Planer Serial number 12 digits.
