Текущее время: 12 май 2024, 00:42
ValeriyKeks
Заголовок сообщения: Re: Lenovo Z510 (AILZA NM-A181 the Rev: 1.0) No +3VALW and +5VALW Добавлено: 13 мар 2016, 23:41 |
Зарегистрирован: 04 ноя 2013, 14:06 Наличности на руках: 54.24
Сообщения: 407 Откуда: Вятская губерния
FRD писал(а): Also KBC is IT8586, if replaced, does it need to be programmed? Yes. Take a here. FRD писал(а): when i remove jumper PJ401 (+3VALWP ---> +3VALW), 3.3volt and 5volt start to appear at corresponding coils. Remove PJ401, connect adjustable power supply (APS) on side +3VALW (pad 1 on schematic). Set up 3V and 1A on APS and power-on APS. Feel by fingers a motherboard all surface on abnormal heating. If heat small or not feel, step up current on 0.5A and again. The broken component will abnormal heating. Probably APS will work in mode "Current limit". This normal if on mother board have a broken component .
ValeriyKeks
Заголовок сообщения: Re: Lenovo Z510 (AILZA NM-A181 the Rev: 1.0) No +3VALW and +5VALW Добавлено: 14 мар 2016, 08:29 |
I chose a long time and chose programmer by S.Vertyanov. I really like this programmer. You can buy it here. You can read and post your questions here.
FRD
Заголовок сообщения: Re: Lenovo Z510 (AILZA NM-A181 the Rev: 1.0) No +3VALW and +5VALW Добавлено: 03 апр 2016, 11:37 |
Зарегистрирован: 12 май 2014, 21:17 Наличности на руках: 70.07
Сообщения: 50 Откуда: Iran
ValeriyKeks писал(а): replace PU904. Check the associated components, especially the feedback resistors. I have checked surrounding resistors, replaced RT8243 (PU904) again the problem persists, also checked feedback voltages, 2v at pins 1,5 available. The point is with PJ401 removed, there is enable signal to PU904, but when PJ401 soldered, Enable is not available. thanks
