https://vlab.su/
LENOVO G70-35 (CG70A NM-A671 REV/1.0) WON'T POWER ON
https://vlab.su/viewtopic.php?f=58&t=55631
Страница 1 из 1
habibou11 [ 11 янв 2017, 19:50 ]
Заголовок сообщения:  LENOVO G70-35 (CG70A NM-A671 REV/1.0) WON'T POWER ON
HI FRIEND I HAVE PROBLEM WITH THIS LAPTOP
I TESTED THE VOLRAGE ON THE BATTERY CONNECTOR THERE IS NO VILTAGE & THERE NO VOLTAGE TOO ON THE FLASH DUMP BUT AT THE POWER BOUTON THERE IS 2.2V
THANKS TO HELP
Azazehl [ 12 янв 2017, 12:46 ]
Заголовок сообщения:  Re: LENOVO G70-35 (CG70A NM-A671 REV/1.0) WON'T POWER ON
Power Button voltage is 3.3V ordinary.
Look where drawdown. Try to check the hall sensor, KBC (MIO), and 3.3V StandBy Bus.
What is voltage on 3.3VSB, 5VSB, B+ ?
http://www.phpbb.com/
