Текущее время: 26 апр 2024, 21:47
scobay
Заголовок сообщения: Re: Lenovo G50-30 (NM-A311) No post low current Добавлено: 02 авг 2017, 23:55 |
Сообщения: 106 Откуда: Ireland
77romantik77 писал(а): What is the resistance of D + D- relative to ground via USB? HI Im not sure what you mean? Posted after 5 minutes 18 seconds:77romantik77 писал(а): What is the resistance of D + D- relative to ground via USB? Apologies I understand D- is 2.48 ohm D+ is 41 ohm
scobay
Заголовок сообщения: Re: Lenovo G50-30 (NM-A311) No post low current Добавлено: 03 авг 2017, 02:29 |
77romantik77 писал(а): Change the processor, this is a typical malfunction for this platform. The reason is the lack of protection over USB
Или как говорят у нас "Вашему комбайну тапки приснились" ---------- Добавлено спустя 4 минуты 27 секунд: ---------- This platform is still stitched with ITE, keep in mind! ---------- Добавлено спустя 7 минут 21 секунду: ---------- Be careful, under the CP compound, use dichloroethane I was hoping it was not the CPU bga chip, where to get dichloroethane in the EU?.
