https://vlab.su/
Lenovo b50-30 (LA-b102p) Usb's Don't work
https://vlab.su/viewtopic.php?f=58&t=71274
Страница 1 из 1
SpinNNN [ 27 янв 2018, 16:43 ]
Заголовок сообщения:  Lenovo b50-30 (LA-b102p) Usb's Don't work  [РЕШЕНО]
Hey guys
I have this machine and the usb's don't work. i have 5v and I already checked the bios and it does not appear.. i Try to reprogram Bios but same problem. Can be a dead processor??
Any one can help me??
thank you
aspirant [ 27 янв 2018, 16:52 ]
Заголовок сообщения:  Re: Lenovo b50-30 (LA-b102p) Usb's Don't work
Check Dataline if fault on these lines then you have 99% CPU dead
IOD [ 27 янв 2018, 16:57 ]
Check the resistances on the lines -D, +D USB with GND.
SpinNNN [ 29 янв 2018, 14:17 ]
Thank you guys for reply..
Usb's 2.0 i have 2,9ohm in -D, +D Datalines... And i have a short to ground in bougth pins. i think CPU is dead??
IOD [ 29 янв 2018, 14:54 ]
yes
SpinNNN [ 29 янв 2018, 21:01 ]
Thank you, i will replace a cpu and after i post the results.
http://www.phpbb.com/
