Текущее время: 01 май 2024, 16:59
 Заголовок сообщения: Lenovo ideapad z500 (windows 10) No charging
СообщениеДобавлено: 22 фев 2018, 22:31
Hello
i am new in laptop repairs,and today i have a customer,with a lenovo ideapad z500 LA-9061P, that its not charging,after some test,i found that if i plug the charger the capacitor PC312 its shorting,if i unplug its not shorting,can someone share a boardview file to check this line or some infos if anybody knows about this problem :-)
thanks for your time :-)
 Заголовок сообщения: Re: Lenovo ideapad z500 (windows 10) No charging
СообщениеДобавлено: 25 фев 2018, 01:46
hello, how can you be sure one capacitor is shorting?
use multimeter and check the resistance to ground on the main power line.
if one capacitator is shorted to ground on main power line , everything will be shorted.
here is schematics, you do not need board view for this one
http://www.s-manuals.com/motherboard/compal_la-9061p
СообщениеДобавлено: 26 фев 2018, 19:33
Hello guys,thanks for the replies
i found the problem
it was the mosfet PQ301 in the power rail of 20V,after replacing this mosfet the laptop was starting boot without battery,but stil the laptop was geting 20V on the battery connector,this is strange,and it was not charging,after some thinking i replaced the mosfet PQ308,because it was on the same rail with PC312,that was shorting only if connecting the power supply(probably because of the short the mosfet was damaged)
now the laptop works and charge!!!
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. IdeaPad Z500 (Z500) самопроизвольные нажатия клавиш
XATRIX
05 ноя 2017, 16:55
berislav12 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba L855 (Windows 7) No charging,no power on with Adapter
в форуме Toshiba
teokarafou
04 май 2018, 09:44
dj_djs Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Ideapad Z500 (.) Проблемы с регулировкой яркости
DeNN
9506
04 дек 2015, 16:18
master_el Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo IdeaPad Z500 (LA-9063P) проблемы после неудачной замены матрицы
alien_2005
4784
01 окт 2014, 21:36
elf22 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo ideapad z500 (Compal LA-9061) Нет силовой дежурки
Grizli_saratov
12
3232
22 сен 2015, 15:39
Сейчас этот форум просматривают: Drug63, hima, RomiK0903 и гости: 61
