Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps https://vlab.su/viewtopic.php?f=58&t=88733 |
abuholm [ 08 апр 2019, 13:18 ] | |
Заголовок сообщения: | Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps |
Hello everyone, an attempt was made to read the EC controller (IT8886HE) with SVOD1, programmer was unable to read the chip but now the laptop is beeping. I have attached the error audio file. Please check and let me know what to do. Thanks in advance. Posted after 1 hour 47 minutes 1 second: Ì really want to know if anyone has had success reading IT8886HE with SVOD1 programmer.. |
recordsman [ 09 апр 2019, 13:08 ] | |
Заголовок сообщения: | Re: Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps |
This multicontroller programmin with SVOD well ... BUT you have a different thikness and step of keyboard connectors on logic board and flex cable from sub board of programmer to logic board/ that is why from 4-5 pins of old flex cabel of programmer connetct2 pins together or no pins... just make some measure via multimeter from one to 30 pin of key board connector to programmer connetcor and you can see that is flex cable have fater pins than mlb KB connector.. ---------- Добавлено спустя 3 минуты 43 секунды: ---------- my reccomendation to you if you have 2nd SVOD version programmer: made a wire mount with conductors from programmer to you EC on board like in nm-a311 board pins with same EC and programming you EC... |
abuholm [ 11 апр 2019, 21:23 ] | |
Заголовок сообщения: | Re: Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps [РЕШЕНО] |
Thank You for the reply. I will take a second look at the connections. |
