Текущее время: 23 май 2024, 06:05
simpleboy123
Заголовок сообщения: F5-572g (quanta zrw) when convert to legacy from uefi,display gone Добавлено: 02 июн 2018, 10:28 |
Зарегистрирован: 06 дек 2014, 08:36 Наличности на руках: 58.25
Сообщения: 140 Откуда: USA
Dear friend caught in a strange fault, machine came for windows installation, changed mode from uefi to legacy display gone. re-flashed bios machine earned, display came as normal but when ever you change bios mod from uefi to legacy, the display will be gone. Decided to install window in uefi mode but secure boot is enabled and you can't disable it. Things which have been done. 1. Bios from official site has been merged and written. 2. complete bios from forum has been flashed. 3. I/O controller it8987e has been replaced and reprogrammed. now don't know what to do .Request to masters kindly assist me on this issue. thanx in advance Posted after 15 minutes 12 seconds:Any suggestions???Please
_________________ do good have good
MSF113
Заголовок сообщения: Re: F5-572g (quanta zrw) when convert to legacy from uefi,display gone Добавлено: 02 июн 2018, 13:45 |
DuMoH4er писал(а): I think your built-in graphic not working correctly External graphic
simpleboy123
Заголовок сообщения: Re: F5-572g (quanta zrw) when convert to legacy from uefi,display gone Добавлено: 11 июн 2018, 15:01 |
Hello, thanks for response and sorry for belated reply because of other repair jobs , want to update the progress as you people suggested me some options. 1. First of all, as from DuMoH4er and MSF113 for external graphic check, and i have checked on extrenal VGA output it gives display properly on external. 2. DuMoH4er asked to check LVDS as i correctly understand, So for this let me explain the problem again, the display only and only goes blank if in bios setup you convert from UEFI to Legacy mode 3. Except this, all works great even you install HD graphic Drivers and play videos on hours, don't makes any problem 4. Now i have tried many options but no luck any other suggestion is welcomed. Thanx in advance.
