Текущее время: 20 апр 2024, 20:10
 Заголовок сообщения: Acer Aspire 7560G (Compal (LA-6991P)) jumping contrast.
СообщениеДобавлено: 06 окт 2013, 09:34
Brought this unit - split matrix. Completely broken down (by ship from one deck to the second moved quickly).
Platform: Compal (LA-6991P).
Matrix stood there: B173RW01 But when replacing the matrix transpired very intriguing defect - jumping the contrast on the display. Went through several matrices - and they either do not show the image, or display, but with a jumping contrast. The main speaker jumping chaotic. Change vref on the matrix resistor slightly improves the display, but the twitching will not disappear - the distortion of colors. Now is the matrix: N173FGE. Firmware matrix does not lead to anything - if drained what was in the previous one - out there. And it all comes down to the same effect - either jerks or not out. BIOS firmware on the different versions is no it does not affect the iso. turned some fluctuation in the power matrix pines - but the overall makeup external power does not change the situation. On signal lines can not see no crime - at least as seen from the oscillograms. Flex is not interrupted - and the impact it has no effect on the picture. Remained all three assumptions: 1. The new matrix is not friends with the frequency of Sloka (maybe that introduces a handful of existing blemishes.) 2. May break out a pair of synchronization - and oscilloscope shows the interpenetration of the signal within the processor array. 3. For this laptop is needed B173RW01 - just look for it. Otherwise - the brain melted
 Заголовок сообщения: Re: Acer Aspire 7560G (Compal (LA-6991P)) jumping contrast.
СообщениеДобавлено: 06 окт 2013, 11:26
Модератор
Модератор
It is a Full HD matrix. It uses 2 LVDS channels. Check their resistance on MB (16 wires, relatively gnd) without matrix.
-приворот winDOвSa
-розыгрыш автоБАНа
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Aspire 7560G (Compal LA-6991P) Не работают USB
gre6nik58
3125
10 фев 2016, 22:11
gre6nik58 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Aspire 7560G (Compal LA-6991P Rev:1.0) Пропадает дискретное видео
vavan-kmv
12
3930
10 июн 2014, 11:16
vavan-kmv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aspire 7560G (Compal LA-6991P Rev:1.0) Помогите c обвязкой 216-0810005
vavan-kmv
13 дек 2014, 00:48
Zet Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 7560G (LA-6991P) Проблема с клавиатурой
snakestudio
18 июн 2014, 05:24
snakestudio Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Aspire 7560G (P7E5 LS-6991P) нужен дамп матрицы B173RW01 V.3
master-hand
18 июл 2014, 12:16
master-hand Перейти к последнему сообщению
Сейчас этот форум просматривают: btomce, volodin и гости: 14
