This laptop brought in No power state. IO and LAN IC is very hot so KBC changed by new one( KB930QF-A1) and LAN IC removed and not replaced. Now by pressing power switch laptop turns ON. We have all Voltages on Voltage rails. But NO Display. and resumes only 0.5 Amperes ( with or without use of RAM consumption not changes). Anyone have any Idea?
_________________ Don't give up without the fight.
adgery
Заголовок сообщения: Re: E-machine E644 (Compal LA-7092P) No display
Добавлено: 14 ноя 2013, 23:15
Зарегистрирован: 26 сен 2011, 22:24 Наличности на руках: 793.02 Сообщения: 122 Откуда: Samara
P.zonouz писал(а):
LAN IC is very hot
It abnormal - may have been a lightning strike or some other powerful electrical pulse. After need check southbridge (hub) - better - replace it.
P.zonouz
