Acer 5741G (Compal LA-5891P) turns off after 4-5 minutes by itself https://vlab.su/viewtopic.php?f=59&t=27589 |
latitude [ 25 дек 2014, 19:39 ] | |
Заголовок сообщения: | Acer 5741G (Compal LA-5891P) turns off after 4-5 minutes by itself |
Hi all, Merry Christmas to all of you! Best wishes to you and your families! Now, the question :) I have Acer 5741G, Compal LA-5891P, Core i3-330, Ati HD5470, 4GB memory. First problem - notebook power on, but no picture, no post. Reball the gpu fix this problem. Now, turn machine on, it works 4-5 minutes and shutdown by itself. It happens in bios, in windows, in dos (hiren's boot). This is what i did: - check all temperature - they're normal. - swap memory (on both dimm's separately) - test with and without HDD - same problem. - test only on external display - same problem - remove ODD, usb board, wifi... - same problem.... - heatsink doesn't become hot. Thermal grease and pad has been replaced with new. I doubt in some capacitors near gpu, which are 0.1uF, 1uF and replace them, but with no result. Does anybody have this problem? |
and555 [ 25 дек 2014, 20:31 ] | |
Заголовок сообщения: | Re: Acer 5741G (Compal LA-5891P) turns off after 4-5 minutes by itself |
replace the GPU will solve the problem. |
latitude [ 25 дек 2014, 21:33 ] | |
I think that too, but gpu is not cheap, that's the reason I would like to see other opinion. Thanks, I will wait for some other answers, and I offer gpu replacement. |
and555 [ 25 дек 2014, 21:43 ] | |
by reball the gpu, usually the problem is the laptop will turn off by itself, usually I make the fan always on in maximum speed(but a bit noisy) to solve this problem. |
latitude [ 25 дек 2014, 21:56 ] | |
and555 писал(а): by reball the gpu, usually the problem is the laptop will turn off by itself, usually I make the fan always on in maximum speed(but a bit noisy) to solve this problem. That means gpu overheating? I see temperatures - there are normal.. |
and555 [ 28 дек 2014, 00:45 ] | |
latitude писал(а): That means gpu overheating? I see temperatures - there are normal.. not means overheating, I also don't understand :) but when fan always on in maximum speed, the laptop works normally. |
latitude [ 29 дек 2014, 02:40 ] | |
Hmm, I understand. Waiting for client decision and we will see :) Thanks again. |
latitude [ 23 апр 2015, 17:42 ] | |
Topic can be closed - problem solved after flashing new bios & ec. |
