https://vlab.su/
Acer Aspire 5336-2283 (PEW72 LA-6631P) No Initialization
https://vlab.su/viewtopic.php?f=59&t=29980
Страница 1 из 1
abuholm [ 04 мар 2015, 18:52 ]
Заголовок сообщения:  Acer Aspire 5336-2283 (PEW72 LA-6631P) No Initialization
Hi everyone, this laptop came with a short on +3V_LAN rail and I realised the LAN chip was shorted so after changing all voltages appear [PL3 3.3V, PL4 5.1V, PL7 1.5V PL8 1.05V PL13/14 1.18V]. The laptop powers on and fan spins for 2 secs and stops but there is no initialization. I also realise that the CPU heats up but not enough to burn fingers . I have flashed the bios. On KBC signals; EC_KBRST# 3.3V, PLT_RST# 0V [resistance to ground is 15.5k], PM_SLP_S3# 3.3V, PM_SLP_S5# 3.3V, SUSP# 3.3V, EC_PWROK 3.3V, LID_SW# 3.3V, SYS_ON 3.3V, VR_ON 3.3V.I want to know if KBC is ok and where else to look.
alansbor [ 04 мар 2015, 20:36 ]
Заголовок сообщения:  Re: Acer Aspire 5336-2283 (PEW72 LA-6631P) No Initialization
Hello !
Pls check resistor PR161 nearest PU12.
nt368 [ 04 мар 2015, 20:57 ]
Hello! Do you have POST card or oscilliscope?
abuholm [ 05 мар 2015, 01:24 ]
the value is 5.03k
Posted after 9 minutes 5 seconds:
I have a POST card but the pc doesn't post [no CLK and no RST].
abuholm [ 06 мар 2015, 00:28 ]
Hi guys .. :nez-nayu: I really need help on what to do next :ne_vi_del:
http://www.phpbb.com/
