5742 (LA-5893) No turn on https://vlab.su/viewtopic.php?f=59&t=33220 |
R EZ A [ 10 июн 2015, 19:55 ] | |
Заголовок сообщения: | 5742 (LA-5893) No turn on [РЕШЕНО] |
Hi guys This laptop turning on with battery,but no action with ac It use 0.04 on ac and it hav 8-10V on B+ Pq21&pq52 gate are high What is the problem? Tnx all |
andromedax [ 10 июн 2015, 21:22 ] | |
Заголовок сообщения: | Re: 5742 (LA-5893) No turn on |
R EZ A писал(а): Pq21&pq52 gate are high Measure the voltages of PQ63. (pin1, pin2) PQ63 shoud be saturated, (high level on pin2) in order to establish the correct voltage on gates of PQ51 and PQ52. Check level voltage from ACOFF signal. |
R EZ A [ 11 июн 2015, 12:01 ] | |
ACOFF=0V PQ63 gate=0v PQ63 Drain=19V |
andromedax [ 12 июн 2015, 13:37 ] | |
R EZ A писал(а): ACOFF=0V PQ63 gate=0v PQ63 Drain=19V Measure and post all pins voltages of PD15. Also check voltage of VL rail. |
gs84 [ 12 июн 2015, 23:12 ] | |
R EZ A писал(а): Pq21&pq52 gate are high what you mean? Say in values volts. PQ51 and PQ52 already checked?
andromedax [ 13 июн 2015, 01:31 ] | |
gs84 писал(а): what you mean? Say in values volts. PQ51 and PQ52 already checked? Why do you suspect PQ51 and PQ52 are damaged? Main problem is PQ63 not being correct polarized. PQ63 Drain=19V is not a good voltage for Pq52 conduction. |
R EZ A [ 13 июн 2015, 16:15 ] | |
VL=5V ACON=0V MAINPWON=Variable 2.5-4V PD15 Pin1=Variable 2-3.5 PACIN=0V ACOFF=0V |
andromedax [ 13 июн 2015, 21:19 ] | |
R EZ A писал(а): VL=5V ACON=0V MAINPWON=Variable 2.5-4V PD15 Pin1=Variable 2-3.5 PACIN=0V ACOFF=0V Check PD1 for short-circuit. Post voltage pin 2 & 3 of PU18A. Check voltage of RTCVREF (3,3v.) Вложение: PACIN.jpg
R EZ A [ 14 июн 2015, 10:47 ] | |
PD1 work correctly PU18: Pin1=0V Pin2=3.3V RTCVREF=3.3v |
andromedax [ 14 июн 2015, 21:14 ] | |
R EZ A писал(а): Pin1=0V Pin2=3.3V Check PR297, PR295, PR296. Replace PU18. Вложение: vin detector.jpg
