Текущее время: 19 апр 2024, 09:18
 Заголовок сообщения: V5-572G (DA0ZQKMB8E0 Rev:E ZQK) Shorted Onboard RAM , NEED HELP, WILL DONATE $$
СообщениеДобавлено: 04 дек 2016, 21:10
OK
acer aspire v5-572g has a shorted onboard RAM
i have removed pq9 chip and injected 3v 0.5A inside of the board, RAM (onboard) started to warm up.
i have injected 5v 1.75A inside and they got even warmer.
when the charger is attached i only get 2V inside.
could the ram be shorted? can i somehow fix this? can the ram be disabled?
http://elektrotanya.com/acer_aspire_v5_ ... nload.html
ofc, you will have my thanks and a little donation ;)
Greetings from ur serbian brother
 Заголовок сообщения: Re: V5-572G (DA0ZQKMB8E0 Rev:E ZQK) Shorted Onboard RAM , NEED HELP, WILL DONATE $$
СообщениеДобавлено: 04 дек 2016, 22:50
No offence, but it`s foolish act - if high-side mosfet broken, high voltages get to low-voltage rails...
check +1.5VSUS and the other rails
after remove all memory banks
board_id1 R162 -> R151 disable onboard memory
СообщениеДобавлено: 05 дек 2016, 22:35
>as i understand, p mosfet will work if the current on the gate is lower then the one on the source?
...voltage on the gate is lower...
, but I think there is very low resistance on VIN line (after PQ9) - need to check
>> (checked, it is little more then 200ohm resistance to ground)
>i did not go above 5v so i do not burn something in the board.
RAM 1.5VSUS, if PQ45 shorted (check it), your 5V go to 1.5V. There are also lots of capacitors 2.5V (see the scheme)... Don`t do that )
>> thanks for the tip :)
Remove Pl13 and measure resistance in both points ( i have did that already and had over 0.45kOhm on one side, and on other side pc156 pc165 i had only 94 Ohm to ground...
so now, should i remove every single capacitor next to ram and check them ? or is the ram chips shorted?
thanks for the advice
ps. i think pq45 is shorted. im going to remove it to test,...
В этой теме нет новых непрочитанных сообщений. Acer V5-572g (DA0ZQKMB8E0 Rev:E ZQK) Will not start, SHORTED!
draganzile
03 дек 2016, 18:45
draganzile Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer v5-572g (DA0ZQKMB8E0 Rev.E Model: ZQK) Не включается от 19в но при 9в работает
coretek
3468
02 май 2018, 22:49
coretek Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ACER V5-572PG-53338G50am m (DA0ZQKMB8E0 REV.E Model ZQK ) Нужны дампы BIOS
VAGner1976
19 авг 2015, 15:31
VAGner1976 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Куплю на разбор Quanta ZQK (DA0ZQKMB8E0)
в форуме Куплю | Buy
mike2520
26 май 2015, 23:51
mike2520 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo g510 (LA-9641p v:1.0) HELP ME MY RUSSIAN BROTHERS! SHORTED CPU VCORE!!!
draganzile
30 окт 2016, 01:33
Сейчас этот форум просматривают: andr-sam.f, AndreyVl96, Boolka, Kostyan-26, w1Sp и гости: 15
