Заголовок сообщения: extensa 5220 (wistron Columbia) charge led is blinking
Добавлено: 11 янв 2018, 22:01
Зарегистрирован: 11 май 2013, 10:38 Наличности на руках: 1,443.20 Сообщения: 741
hi all , when i press power button with only battery the charge led is blinking for while and the laptop dose not turn on , but when i connect ac power the led is not blinking and also laptop dose not turn on , all voltage and bios are ok in both cases , i have changed kbc but nothing change , plese i need help ............
vldmrdnpr
Заголовок сообщения: Re: extensa 5220 (wistron Columbia) charge led is blinking
