Текущее время: 25 апр 2024, 19:28
andromedax
Заголовок сообщения: Re: Acer 5741G (Compal LA-5891P) turns off randomly Добавлено: 29 май 2019, 19:33 |
Сообщения: 262 Откуда: Alicante, Spain
Цитата: Is the CPU voltage stable? use an oscilloscope Yes cpu voltage is stable and has no ripple. (only has the small variations that are normal during boot) I have activated F12 in bios setup in order to select boot device, and when boot, if detects F12, shows the boot menu forever, but if select a device and press enter, it turns off. Regards.
andromedax
Заголовок сообщения: Re: Acer 5741G (Compal LA-5891P) turns off randomly Добавлено: 29 май 2019, 23:11 |
Цитата: remove battery cmos The cmos battery had been removed at first, and did some test without it, but now it's soldered again. I will remove again and continue the test without it. I have put a password on boot, and it start always asking for the password, and doesn't turns off, only when I write the password and press enter, it turns off. A very weird thing. Hope someone has had this problem before and can help me. Thanks.
andromedax
Заголовок сообщения: Re: Acer 5741G (Compal LA-5891P) turns off randomly Добавлено: 30 май 2019, 19:15 |
Цитата: If U9 is installed, raise the 6th pin. If this solves the problem, replace the graphics processor. PU30 is not soldered in the circuit since I started to make the tests, but I have not tested U9. I will try it and post if success or not. Regards. Posted after 2 hours 38 minutes 41 second:hi, majemus I have removed U9 and it works and loads windows. I will put a new U9 and will test. (it's easy than change the gpu) I will let you know the results.
andromedax
Заголовок сообщения: Re: Acer 5741G (Compal LA-5891P) turns off randomly Добавлено: 31 май 2019, 19:36 |
Цитата: If you replace the U9, this will not solve the problem. The problem is with the thermal diode of the GPU. When replacing the U9, you will have a thermal effect on the GPU and it will work, but it will not fix it. It works ok without U9, but I have ordered a new gpu. I think the new gpu will solve the problem definitely. Thanks for your help.
