Текущее время: 28 мар 2024, 16:48
paulleshchenko
Заголовок сообщения: Nokia N9 (оригинал) не удается прошить Добавлено: 02 янв 2015, 01:51 |
Сообщения: 411 Откуда: Украина
не могу прошить телефон, шил через flasher из виндыи линукса останавливается на одном и том же доходит до раздела rootfs и дальше не шьется.
Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_001 Device mode : Production mode
прошивку качал из navifirmplus_3.2 через DownlodMaster контрольную сумму сверял через BEST
USB device found at bus 001, device address 021. Device identifier: 357923043593112 (SN: N/A) Raw data transfer EP found at EP2. Ping attempt 1 (250 ms) Server application: 1.7.2 Found product RM-696 rev. 1603 Server implements softupd protocol version 1.8 Image SW version DFL61_HARMATTAN_40.2012.21-3_PR_001 Image moslo not present Image mmc not present Image tar skipped Image config skipped
Battery level 25 %, continuing.
image [state progress transfer flash speed] --------------------------------------------------------------------- [x] cert-sw [finished 100 % 1 / 1 kB NA ] [x] cmt-2nd [finished 100 % 95 / 95 kB NA ] [_] cmt-algo [init 100 % 789 / 789 kB NA ] [ ] cmt-mcusw [pending 0 % 0 / 0 kB NA ] [x] xloader [finished 100 % 23 / 23 kB NA ] [x] secondary [finished 100 % 94 / 94 kB NA ] [x] kernel [finished 100 % 2714 / 2714 kB 1903 kB/s] [_] rootfs [finishing 100 % 23552 / 1170282 kB NA ] ERROR: SU_PREPARE_DATA_BLOCK_REQ terminated with error code 3: Invalid state
image [state progress transfer flash speed] --------------------------------------------------------------------- [x] cert-sw [finished 100 % 1 / 1 kB NA ] [x] cmt-2nd [finished 100 % 95 / 95 kB NA ] [x] cmt-algo [finished 100 % 789 / 789 kB NA ] [x] cmt-mcusw [finished 100 % 6050 / 6050 kB 3461 kB/s] [x] xloader [finished 100 % 23 / 23 kB NA ] [x] secondary [finished 100 % 94 / 94 kB NA ] [x] kernel [finished 100 % 2714 / 2714 kB 1903 kB/s] [f] rootfs [finishing 0 % 25600 / 1170282 kB NA ] Fetching error list: ======================================== Update content failed to verify against cert: SW certificate not updated bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed mmc: sfdisk returned status 1 mmc: Could not exec 'tune2fs -L rootfs /tmp/sudmmcHdktLc/internal0p2' mmc: Could not remove mount directory /tmp/sudmmcHdktLc/mnt: No such file or directory [Pipe 4] Finishing in error state with status 1 ========================================
ERROR: Failed to flash images ---------- Добавлено спустя 25 минут 50 секунд: ---------- вот лог из BEST
card found: A1B5CCE8 registered to: CycloneBox
Connect phone on selected interface...
Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin ========== FW APE version : 40.2012.21-3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : EUROPE [1] , America (Latin , South), South Africa FW Region ver : 001 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok !
Core : v1.51 , FlashEngine : v2.01
Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok!
Read info Ok
Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok
Reopening the connection...
RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 72 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mmc,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed
Code Match Ok HW match Ok
RFS : Performing SWAP WIPE... Starting Wipe... Bat.level : 72 Battery voltage is enough, starting wipe... Formatting... Can take up to 15-50 minutes, wait until process complete Do not disconnect phone, until done! Wipe error!!!! Something went wrong :( Wipe failed...
Prepare on format error Try again few times. Check cable and battery
Elapsed: 00:00:45 Connect phone on selected interface...
paulleshchenko
Заголовок сообщения: Re: Nokia N9 (оригинал) не удается прошить Добавлено: 09 янв 2015, 00:21 |
djamal писал(а): флешь дохнуть . и что делать с флешем? где брать?
spam1012
Заголовок сообщения: Re: Nokia N9 (оригинал) не удается прошить Добавлено: 15 янв 2015, 17:24 |
Сообщения: 156 Откуда: Krasnoyarsk
paulleshchenko писал(а): не загружался, попусту не шил комп менял?дрова?флешки не болезнь нокии а таки самцов....атф в помошь.отдайте у кого боксы есть. пока не дошили в усмерть...
