добрый день, уважаемые форумчане. телефон включается с IMEI 12345 дело в том, что не могу с ним ничего сделать программатором (mxbox)
вот лог BUS Check
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085хххх Using device: HTI, FW ver: 00.24, SN: 0000хххх Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 2D4A8F43BCB00FE9DD4AF31A5CF5A2F8F6902BC0 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 196001177E730052739C2D973C61DDAB6B591D7D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 reading boot config 1 failed!
всё, дальше дело не идет, в углу мигает Ready
лог Scan
Version from phone: 06wk41v64.24 Version from file: 35.0.002 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085xxxx Using device: HTI, FW ver: 00.24, SN: 0000xxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Invalid imei plain, RPL backup skipped. APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 2D4A8F43BCB00FE9DD4AF31A5CF5A2F8F6902BC0 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 196001177E730052739C2D973C61DDAB6B591D7D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Total time for flashing process(boot+erase+write) was 20.782 s Phone type: RM-313 (Nokia N82) SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 12345610654321-? Product code: 0551526 Battery voltage: 3945 mV, current: 112 mA Language Pack: - not available.
SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted!
не прошивает
Version from phone: 06wk41v64.24 Version from file: 35.0.002 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085xxxx Using device: HTI, FW ver: 00.24, SN: 0000xxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Invalid imei plain, RPL backup skipped. APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 2D4A8F43BCB00FE9DD4AF31A5CF5A2F8F6902BC0 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 196001177E730052739C2D973C61DDAB6B591D7D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 reading boot config 1 failed! Total time for flashing process(boot+erase+write) was 21.657 s Phone type: RM-313 (Nokia N82) SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 12345610654321-? Product code: 0551526 Battery voltage: 3962 mV, current: 110 mA Language Pack: - not available.
не стирает
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085хххх Using device: HTI, FW ver: 00.24, SN: 0000хххх Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 2D4A8F43BCB00FE9DD4AF31A5CF5A2F8F6902BC0 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 196001177E730052739C2D973C61DDAB6B591D7D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 reading boot config 1 failed! Process failed !
естевственно, не могу залить RPL, не могу восстановить. что ему надо? через UFS стирает и шьет
