Текущее время: 23 май 2024, 05:36
 Заголовок сообщения: MSI GE60 (ms-16gc1 rev:1.1) Will not start
СообщениеДобавлено: 16 фев 2017, 20:56
Hi, i have a problem with MSI GE60 laptop
Laptop was shorted , found the short (was one of the capacitors next to the gpu power , just removed couse dont have spare board and dont have schematics )
After that, i found that the mosfets pq25 and pq26 have 19v input but on the output i get only 15v , models are ao4413 and ao4447 p channel
i have replaced them with SI4825 ( i know these are not equivalent and are lower , but only wanted to test if i got 19v on the output)
after i have replaced them, i got 19v current
now problem is:
laptop will not start
i really need schematics to solve this, if anyone does, please let me have it.
as i know, laptop needs to have 19v , 3.3v and 5v to be able to start , i have 3.3v on the battery pins 3x 3.3v , also i have 2.7v x2 on battery connector, so the charging is good.
when pressing power button, laptop will not start.
checked pu4 i had 19v on pc 58 and 5v on pc59, i have shorted by accident pc58 and pc59 and now there is no 5v or 3.3v (probably controller died )
now , this is some f***ed up situation.
on the controller i could see 1225c mark , but not sure controller is 4x5 pin output , tps51225c is not, it is 4x6 pin
could be possible that the ec is dead ? could be possible that ec only needs to reprogrammed?
could this pc58 and pc59 shorting burn something else?
schematics anyone?
 Заголовок сообщения: Re: MSI GE60 (ms-16gc1 rev:1.1) Will not start
СообщениеДобавлено: 02 мар 2017, 19:15
draganzile писал(а):
schematics anyone?
Big photos only:
viewtopic.php?p=249536#p249536
http://notebook1.ru/forma1/viewtopic.ph ... 42#p692242
But not good quality...
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI ge60 (ge60) sop8
в форуме MSI
Roman1019
06 авг 2017, 17:42
kent_3g Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI MS-16GC1 VER 1.1 . Нет дежурного напряжения 3,3 / 5v
в форуме MSI
Евгений3Lan
2619
24 авг 2018, 14:11
В этой теме нет новых непрочитанных сообщений. MSI GE 60 (ms-16gc1 v1.1) нет изображения
в форуме MSI
nsdxack
972
24 янв 2022, 09:20
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MS-16GC1 VER:1.0 - нет заряда батареи.
в форуме MSI
Александр_Т
17 окт 2016, 18:28
Александр_Т Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MS-16GC1 VER:1.0 - нет изображения.
в форуме MSI
Александр_Т
21 ноя 2016, 14:48
