Текущее время: 28 апр 2024, 03:49
Serguz05
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 28 май 2022, 20:00 |
Зарегистрирован: 09 фев 2013, 23:45 Наличности на руках: 5,138.05
Сообщения: 2309 Откуда: Riga
where are the measurements? resistance / voltage. or is it necessary to guess. R EZ A писал(а): it was Q22 and after replacing mosfet and it keeps burning and RAM is whole? worker ? if the RAM is burned out, then the processor is probably too. After all, the processor communicates directly with RAM.
R EZ A
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 29 май 2022, 11:03 |
Зарегистрирован: 08 дек 2013, 21:10 Наличности на руках: 226.84
Сообщения: 406 Откуда: Earth
Serguz05 писал(а): and RAM is whole? worker? if the RAM is burned out, then the processor is probably too. After all, the processor communicates directly with RAM.
i mean mosfet keeps burning after replacment i tried replacing TPS51216(pu5) without mosfets it turns on to 0.2A and 3.3v ,5v and +1V_SUS is on after adding mosfets it goes to short circuit and even without mosfets use 1.2A when turned on so pu5 died again i have no more TPS51216 and replaced by G5316RZ1D now it turnes on and use 0.2A again how can i find does pwm work correctly and dont kill mosfets again
Serguz05
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 29 май 2022, 14:45 |
R EZ A писал(а): i mean mosfet keeps burning after replacment is RAM installed? if the RAM is defective, then PU5 may burn out. you also need to check the PU5 harness. what on VBST 15pin, pr72, pc39, pr86, what is the resistance on Choke6 with ram and without ram.
R EZ A
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 29 май 2022, 16:31 |
Serguz05 писал(а): is RAM installed? if the RAM is defective, then PU5 may burn out. you also need to check the PU5 harness. what on VBST 15pin, pr72, pc39, pr86, what is the resistance on Choke6 with ram and without ram.
its all without ram +1_2VDIMM looks short to ground: 1 Ohm i remove pu5 ,q22,q244 and still 1 ohm is it harmful to apply 1V to output?
Serguz05
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 29 май 2022, 16:53 |
R EZ A писал(а): 1 Ohm Well, here's the problem. you can apply 1v and see what is heated.
R EZ A
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 31 май 2022, 17:07 |
Serguz05 писал(а): Well, here's the problem. you can apply 1v and see what is heated. cpu get warm but its not short circuit it just use 1A and cpu softly get warm
Serguz05
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 31 май 2022, 17:15 |
R EZ A писал(а): +1_2VDIMM looks short to ground: 1 Ohm there should not be 1om. If only the processor is heating up, then it is most likely bad. p.s. and most likely RAM too.
R EZ A
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 31 май 2022, 18:24 |
Serguz05 писал(а): there should not be 1om. If only the processor is heating up, then it is most likely bad. ps and most likely RAM too. for last test i decided to put G5316RZ1D and mosfets surprisingly it doesn't burn and 1.2V runs normally! but with or without ram uses same current:0.3A and no VCC_CORE,VCCSA or VCC_GT EC_ALLSYSPG = 3.3V
R EZ A
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 01 июн 2022, 16:46 |
Serguz05 писал(а): what is the resistance. ---------- Added after 6 minutes 39 seconds: ---------- you can try flashing the bios. MSI website has clean bios and ME dump.
its 2.2 omh now i already tried dump file in forum also flashed file from msi website and all was same
Serguz05
Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage Добавлено: 01 июн 2022, 17:26 |
R EZ A писал(а): for last test i decided to put G5316RZ1D and mosfets surprisingly it doesn't burn and 1.2V runs normally! R EZ A писал(а): its 2.2 omh now this resistance in the RAM power circuit is extremely low. there is no point in flashing bios.
