Текущее время: 28 апр 2024, 02:30
 Заголовок сообщения: Прошивка для Asus P525
СообщениеДобавлено: 22 янв 2010, 20:09
Прошивка для Asus P525 версии 3.43.0
Asus PDA Phone P525’s latest English firmware V3.43.0(Not for KSA, Russia, Israel,Turkey)
**This upgrade is for those English units that are NOT bought from the countries mentioned above.
Additional features and improvements:
1. Improved occasional silence scenario during call out while using BT headset(HFP) and disabled "Standard Audio" function.
2. Improved silence scenario during recording while using BT headset in telephony.
3. Improved power consuming scenario during sleep mode while using BT headset(HFP/A2DP).
4. Improved occasional sound drop during playing of music while using BT headset(A2DP).
5. Improved security concerns of "My Secret Folder".
Caution:
1. Do not upgrade to different language or regional version onto your PDA Phone.
2. Please also install phone module firmware V4.6.0.
3. After the installation, previous information will be erased. Please execute backup by using bundled backup software before installation.
4. After the installation, please go to "Start"=>"Programs" and restore back to default.
Please follow the below procedures to upgrade:
1. Please format your Mini-SD first.
2. Unzip the file and copy it to Mini-SD card’s root folder(Under Mini-SD’s root folder, there should only be folder 2577 and Galaxy.cap; In folder 2577, there should only be Autorun.exe).
3. Insert the Mini-SD with upgrade firmware into P525’s expansion slot and wait for firmware to setup automatically. If the firmware didn’t execute automatically, please execute Autorun.exe in Storage Card\2577\.
4. Follow steps indicated on screen until the installation is complete.
5. Please Confirm version in "Start"=>"Setting"=>"System"=>"System Information"=>"Version".
p525_v3430_wwe.zip
 Заголовок сообщения: Русская прошивка для Asus P525 WM6.1
СообщениеДобавлено: 22 янв 2010, 20:14
WM 6.1 OS CE 5.2.19214 (Сборка 19214.1.0.4)
Удалено:
Transcriber
AUTOUPDATE
FWUPDATE
SQM (Service Quality Management)
Catalog (Marketplace)
Картинки, звоночки, темы, скины для WMP из OEM ASUSa
Состав:
ASUS SIM Card Manager v.1.1.0.1
Jeodek 20080228 RUS
Mobile Office Full
One Note
Remote Desktop Mobile
ScrOFF 8 rel 002
Windows Live
Welcome Center
BCR View
Profile (из Р320)
Ring Tone
Secret Archive
Voice Commander
Bigix ModeSMS v.2.0 RUS
Connect Alert
Network - Настройка Сети из Р750
BSwitch
IE menuext - Добавляет в меню IE пункт “Повернуть экран” (Меню>Сервис>Повернуть экран)
Intruders MCSmsFix v.04
MMS JATAAYU v.4.1.140 (из Р320)
NetCF - 3.5.7283.0
Call History - Добавляет закладки в Историю звонков, (Все, Входящие, Исходящие, Пропущенные)
PulseVibra Sorg Mod
Т9
QuickMenu (Быстрое Меню) - вызывается нажатием на клавишу Win (флажок) или тап на флажок слева от Пуск.
ASUS Image Editor (из Р320)
Плагин o2 Last Call
MenuSounds XDA - включает звук в меню
То что не указано в списках Удалено и Состав из стандартного софта, есть в прошивке по умолчанию.
ASUS.P525.WM6.1.RUS.v.5.0.US.FULL.By.Alexx~.rar
 Заголовок сообщения: Re: Прошивка для Asus P525
СообщениеДобавлено: 09 июл 2010, 21:06
какая прошивка для них самая последняя?
СообщениеДобавлено: 09 июл 2010, 21:24
Администратор
Администратор
На данный момент последняя официальная прошивка на ASUS P525 версии 4.0.10
ASUS PDA Phone P525 WM6 firmware V4.0.10_RUS only for Russia
1. Compare with previous Microsoft Windows Mobile 6 improved stability & performance
2. Extended ROM Version V1.4.2
Caution:
1. Please do not upgrade to different language or regional version onto your PDA Phone, or it may cause device OS broken then it will not turn on anymore.
2. It is recommended to format SD card into FAT format.
3. Please also install Radio Firmware V4.7.0 or above.
4. After the installation, previous data will not be found.
If your OS version is WM5, please use ActiveSync to synchronize and backup your personal data.
(Please do not use SPB Backup to backup and restore your personal data. This action might cause system malfunction or data missing)
If your OS version is already WM6, please use SPB Backup software to Backup your personal Data.
5. Due to compatibility issue, please use ActiveSync version 4.5
http://www.microsoft.com/downloads/deta ... 09f8141141
6.Please make sure battery level is above 60%
7.Please make sure to use Mini-SD card with capacity 2G or less for upgrade.
8.Please make sure that there is no other folder named "2577".
If such folder exist, please rename it to a different name then change it back after upgrade.
9.After the installation, please go to "Start"=>"Setting"=>"System" and restore back to default.
10.Please be notified that it cannot be downgraded to Mobile 5 after upgraded to Mobile 6.
Please make sure you acknowledge such limitation and then proceed with the following steps.
1.Please format your Mini-SD first.
2. Unzip the file and copy it to Mini-SD card''s root folder
Under Mini-SD''s root folder, there should only be folder 2577 Galaxy.cap, Galaxy1.cap, Galaxy2.cap, AsP525.cap. In folder 2577, there should only be Autorun.exe
3. Insert the Mini-SD with upgrade firmware into P525’s expansion slot and wait for firmware to setup automatically. If the firmware does not execute automatically, please execute Autorun.exe under folder . When ‘Upgrade Firmware’ appears, please choose ‘Yes’
4.Click "System" => "Update ROM"
5.System will enter update mode, here the first part of upgrade will start.
Warning: Do not interrupt the upgrade process. Please execute the rest of the steps until completing Step 8 in order for the unit to execute normally.
After the upgrade is complete, a message in red will be displayed.
Please press and hold Power button and reset at the same time to start second part of upgrade.
6.After reboot, it will automatically enter update mode. This upgrade takes about 3 mins, please wait patiently.
Please do not interrupt the upgrade process. After upgrade is done, system will reboot automatically.
8.Please Confirm version in "Start"=>"Setting"=>"System"=>"System Information"=>"Version".
Переводить не буду, добавлю только то, что после обновления этой прошивкой, обновите прошивку радиомодуля до версии 4.7.0
P525_V4010_RUS6nd.zip
P525-FW-V4700.zip
СообщениеДобавлено: 19 апр 2011, 11:54
Ставил Win 6.5.1 сборку - не тормозит, все отлично. SPB wheel тож отлично работала. Продал правда потом Асус за 1500р - надоел глючить джойстик. Если надо - прошивку выложу.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Прошивка тюнера (dump_2flash) STRONG SRT 8502 5.4.3 прошивка
в форуме Мобильные модемы для сотовых сетей | Mobile modems for cellular networks
myhamor
21 фев 2016, 14:48
basozy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X552MJ (Asus X550MD Rev2.0) прошивка мульта
hoten4ik
03 авг 2018, 17:32
В этой теме нет новых непрочитанных сообщений. All-in-One PC Asus ET2311I (Asus ET2311I) Нужна прошивка скаляра
Sebud
28 ноя 2018, 17:12
Sebud Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS VivoBook S15 S510UQ-BQ847T (X510UNR rev 3.0) ASUS S510UQ - прошивка мультиконтроллера IT8595E
joub
12
2958
28 апр 2021, 16:39
Ykv_jrch Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS N750JV прошивка bios, странна история.
в форуме Asus
patriot
14
6032
02 окт 2014, 03:37
patriot Перейти к последнему сообщению
