На данный момент последняя официальная прошивка на ASUS P525 версии 4.0.10ASUS PDA Phone P525 WM6 firmware V4.0.10_RUS only for Russia
Additional features and improvements:
1. Compare with previous Microsoft Windows Mobile 6 improved stability & performance
2. Extended ROM Version V1.4.2
Caution:
1. Please do not upgrade to different language or regional version onto your PDA Phone, or it may cause device OS broken then it will not turn on anymore.
2. It is recommended to format SD card into FAT format.
3. Please also install Radio Firmware V4.7.0 or above.
4. After the installation, previous data will not be found.
If your OS version is WM5, please use ActiveSync to synchronize and backup your personal data.
(Please do not use SPB Backup to backup and restore your personal data. This action might cause system malfunction or data missing)
If your OS version is already WM6, please use SPB Backup software to Backup your personal Data.
5. Due to compatibility issue, please use ActiveSync version 4.5
http://www.microsoft.com/downloads/deta ... 09f81411416.Please make sure battery level is above 60%
7.Please make sure to use Mini-SD card with capacity 2G or less for upgrade.
8.Please make sure that there is no other folder named "2577".
If such folder exist, please rename it to a different name then change it back after upgrade.
9.After the installation, please go to "Start"=>"Setting"=>"System" and restore back to default.
10.Please be notified that it cannot be downgraded to Mobile 5 after upgraded to Mobile 6.
Please make sure you acknowledge such limitation and then proceed with the following steps.
Please follow the below procedures to upgrade:
1.Please format your Mini-SD first.
2. Unzip the file and copy it to Mini-SD card''s root folder
Under Mini-SD''s root folder, there should only be folder 2577 Galaxy.cap, Galaxy1.cap, Galaxy2.cap, AsP525.cap. In folder 2577, there should only be Autorun.exe
3. Insert the Mini-SD with upgrade firmware into P525’s expansion slot and wait for firmware to setup automatically. If the firmware does not execute automatically, please execute Autorun.exe under folder . When ‘Upgrade Firmware’ appears, please choose ‘Yes’
4.Click "System" => "Update ROM"
5.System will enter update mode, here the first part of upgrade will start.
Warning: Do not interrupt the upgrade process. Please execute the rest of the steps until completing Step 8 in order for the unit to execute normally.
After the upgrade is complete, a message in red will be displayed.
Please press and hold Power button and reset at the same time to start second part of upgrade.
6.After reboot, it will automatically enter update mode. This upgrade takes about 3 mins, please wait patiently.
Please do not interrupt the upgrade process. After upgrade is done, system will reboot automatically.
8.Please Confirm version in "Start"=>"Setting"=>"System"=>"System Information"=>"Version".
Переводить не буду, добавлю только то, что после обновления этой прошивкой, обновите прошивку радиомодуля до версии 4.7.0Вложение:
P525_V4010_RUS6nd.zip
Вложение:
P525-FW-V4700.zip
