Текущее время: 25 апр 2024, 19:18
 Заголовок сообщения: acer aspire 7750 (LA-6911P rev:1.0) dim display on lcd
СообщениеДобавлено: 10 апр 2014, 03:34
Hi!
acer aspire 7750 display is ok on external monitor, but dim on led lcd.
Main Voltages measured on JLVDS1 connector pins :
+INVPWR_B+ : 21V
Local_Dim_R : 0.8 to 1.1V
INVTPWM : 3.6V
+3VS : ok
+LCDVDD : 3.6v
+5VS : ok
But BKOFF# : 0V ???
I guess that BKOFF# should be around 3v to enable backlight. Isn't true ?
BKOFF# issued from EC kb930QF to JLVDS1 pin6 is supplied with 3VS through R342 (10k) and grounded through R15 (10k) // C6.
BKOFF# resistance to ground measured about 4 ohms ?? Though I desoldered C6, resistance remained the same.
Does I have to replace the EC to get BKOFF# high and led backlight enabled?
Please advise further.
Thank you
 Заголовок сообщения: Re: acer aspire 7750 (LA-6911P rev:1.0) dim display on lcd
СообщениеДобавлено: 10 апр 2014, 14:28
measured BKOFF# without LVDS cable? powered on/off?
СообщениеДобавлено: 10 апр 2014, 14:39
Wish to correct "Does I have to replace the EC to Get High and BKOFF # LED backlight enabled?"
Does I have to replace the EC to Get BKOFF# High and LED backlight enabled?
СообщениеДобавлено: 10 апр 2014, 16:32
My question refers to check the LCD cable, because you have not written about resistance to ground measured 4 ohms with cable or not.
And about your question:yes
СообщениеДобавлено: 10 апр 2014, 18:55
hi
BKOFF# resistance to ground is 4 ohms without cable.
cable continuity checked ok.
 Заголовок сообщения: Re: acer aspire 7750 (LA-6911P rev:1.0) dim display on lcd  [РЕШЕНО]
СообщениеДобавлено: 26 апр 2014, 01:20
This feed back might help other members. Issue solved.
Found E/C BKOFF# pin shorted, and R342 supplying BKOFF#pin with 3vs missing.
В этой теме нет новых непрочитанных сообщений. Acer (KAV60 LA-5141p) led dim display
pkurls
07 июл 2015, 14:38
s0ulbl4d3 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 7750 (P7Ye09 LA-6911P Rev: 1.0) Выключается при на стадии boot OS
mechnn
2091
24 май 2016, 00:20
Sendman Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Aspire 7750 (LA-6911p) полосы при обоновлении экрана
rolonol
12 янв 2017, 10:49
rolonol Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 7750 ((LA-6911p)) жгет PQ8
d38rus
3151
09 фев 2017, 12:26
youngwar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ACER Aspire 7750 P7YE0 (LA-6911P) При нагрузки отключается от БП но нормально работает от батареи
Anchar777
26 дек 2019, 17:03
Сейчас этот форум просматривают: bleak, FADRA, slaiderpc, TINT, Win_Thunder и гости: 31
