Текущее время: 28 мар 2024, 17:35
ViktorM
Заголовок сообщения: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 16 апр 2011, 11:35 |
Зарегистрирован: 05 ноя 2010, 18:01 Наличности на руках: 1,542.02
Сообщения: 876 Откуда: Ukraine, Rivne
Соответствие Acer Aspire One, Ferrari One, Ferrari - Платформа/Проект Acer Aspire One, Ferrari One
МОДЕЛЬ | ПЛАТФОРМА | НАЛИЧИЕ СХЕМЫ | SERVICE GUIDE | ACER Aspire One | COMPAL LA-5141P (KAV60, KAVA0, JV01-DV, BA02-DV) | yes | | ACER Aspire One, AO521 | QUANTA ZH9 | yes | yes | ACER Aspire One, AO522 | COMPAL LA-7072P (P0VE6, JE01-BZ) | no | yes | ACER Aspire One, AO531h | QUANTA ZG8 (BA01-DV) | yes | yes | ACER Aspire One, AO532h | COMPAL LA-5651 (NAV70, NAV50, JV01-PT) | yes | yes | ACER Aspire One, AO532G | COMPAL LA-6091 (NAVD0) | yes | | ACER Aspire One, AO533 | COMPAL LA-6222P (NAV80) | no | yes | ACER Aspire One, AO571h | COMPAL LA-5031P (KAW10) | no | | ACER Aspire One, AO721 | WISTRON JV10-NL, SJV10-NL | yes | | ACER Aspire One, AO751h | QUANTA ZA3 (JM11-ML) | yes | yes | ACER Aspire One, AO752 | QUANTA ZH7 (JM11-MS, SJM11-MS) | yes | yes | ACER Aspire One, AO753 | WISTRON JV10-CS | yes | | ACER Aspire One, AOA110 | QUANTA ZG5 | yes | yes | ACER Aspire One, AOA150 | QUANTA ZG5 | yes | yes | ACER Aspire One, AOD150 | COMPAL LA-4781P (KAV10) | yes | yes | ACER Aspire One, AOD250 | COMPAL LA-5141P (KAV60, KAVA0, JV01-DV, BA02-DV) | yes | yes | ACER Aspire One, AOD255 DDR2 | COMPAL LA-6221P (PAV70 DDR2) | yes | | ACER Aspire One, AOD255 DDR3 | COMPAL LA-6421P (PAV50) | yes | | ACER Aspire One, AOD255e DDR2 | COMPAL LA-6221P (PAV70 DDR2) | yes | | ACER Aspire One, AOD255e DDR3 | COMPAL LA-6421P (PAV50) | yes | | ACER Aspire One, AOD260 DDR2 | COMPAL LA-6221P (PAV70 DDR2) | yes | | ACER Aspire One, AOD260 DDR3 | COMPAL LA-6421P (PAV50) | yes | | ACER Aspire One, AOHAPPY DDR2 | COMPAL LA-6221P (PAV70 DDR2) | yes | | ACER Aspire One, AOHAPPY DDR3 | COMPAL LA-6421P (PAV50) | yes | | ACER Aspire One, AOP531h | COMPAL LA-5141P (KAV60, KAVA0, JV01-DV, BA02-DV) | yes | yes | ACER Aspire One, AOP531f | COMPAL LA-5141P (KAV60, KAVA0, JV01-DV, BA02-DV) | yes | yes | ACER Ferrari One, FO200 | QUANTA ZH6 | no | |
Acer Ferrari
МОДЕЛЬ | ПЛАТФОРМА | НАЛИЧИЕ СХЕМЫ | SERVICE GUIDE | ACER Ferrari 1000 | QUANTA ZH3 | yes | yes | ACER Ferrari 1002WTMi | Wistron Bolsena-E(AB2) | yes | | ACER Ferrari 1100 | WISTRON Ferrari 7 | yes | yes | ACER Ferrari 1200 | WISTRON Ferrari 7 GT | yes | yes | ACER Ferrari 3000 | QUANTA Zi3 | yes | yes | ACER Ferrari 3200 | QUANTA Zi5 | yes | yes | ACER Ferrari 3400 | QUANTA Zi5 | yes | yes | ACER Ferrari 4000 | QUANTA ZF3 | yes | yes | ACER Ferrari 5000 | QUANTA ZC3 | yes | yes |
ViktorM
Заголовок сообщения: Re: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 18 апр 2011, 09:10 |
Цитата: Compal LA-6221 -> NAV70 и PAV70 здесь поправка - NAV70 - COMPAL LA-5651 Цитата: KAW10 -> на самом деле Compal LA-5031 Спасибо Цитата: Возможно, эту информацию имеет смысл вынести в отдельный столбец. Надеюсь, она полезна. Возможно и полезна.
gecube
Заголовок сообщения: Re: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 18 апр 2011, 12:24 |
Зарегистрирован: 19 ноя 2010, 06:16 Наличности на руках: 304.01
Сообщения: 632 Откуда: Dark side of the moon
Цитата: здесь поправка - NAV70 - COMPAL LA-5651 Неточно. NAV70 - это LA-5651, LA-6221, и, наконец, LA-6222.
_________________ Большой и толстый тролль. А еще лжец и девственник.
ViktorM
Заголовок сообщения: Re: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 19 апр 2011, 06:51 |
Спасибо. Теперь картина дорисована, покрайней мере у меня в голове по компалу. Наблюдал странности при переходе от модели к модели, а теперь все ясно, попробую свою мысль, для себя в начале организовать в таблицу аля Проэкт(модель)-history(модификация)-ревизия думаю выплывет много интересного. Я понимаю что существование каких зависимостей в виде таблиц или намеков гдето существует но доступа к такой информаии нет, а хочеться понять саму логику. Иногда вскроеш ноут и как дежавью уже такую плату смотрел, лезеш в базу такой платы в руках недержал но в памяти все елементы на плате крутяться и становяться на свои места отличия есть но несущественные. Для меня в компале есть белые пятна но наверное их уберу, пока времени нехватает. Спасибо за информацию.
gecube
Заголовок сообщения: Re: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 19 апр 2011, 10:35 |
Сообщение не в тему Цитата: совместимость по чипам это как бы в перспективе или я неправ. В теории - да, на практике - процентов 90% чипов на самом деле взаимозаменяема. Просто нужно немного приложить голову и руки.
D@nilYcH
Заголовок сообщения: Re: Соответствие Acer Aspire One, Ferrari - Платформа/Проект Добавлено: 29 янв 2013, 16:53 |
Зарегистрирован: 03 июн 2012, 20:44 Наличности на руках: 188.15
Сообщения: 170 Откуда: Moscow
COMPAL LA-7071P P1VE6 2011-03-17 1.0 Acer Aspire One 722 yes COMPAL LA-7072P P0VE6, P0VH6 (JE01-BZ) 2010-11-18 1.0 Acer Aspire One 522 Отсюда
