Текущее время: 29 мар 2024, 19:00
 Заголовок сообщения: gigabyte GA-G31M-ES2C rev: 1.1 Strange bios fault on the motherboard
СообщениеДобавлено: 12 апр 2017, 00:58
When I turn on the motherboard it appears on the monitor screen the following image of the bios defect that ends up being looped.
 Заголовок сообщения: Re: gigabyte GA-G31M-ES2C rev: 1.1 Strange bios fault on the motherboard
СообщениеДобавлено: 12 апр 2017, 19:24
Perhaps the bios of the wrong revision was mistake recorded?
Try dl new bios from giga site.
P.s. Perfect if you use programmer
Сильно не бейте, только учусь. Туплю =). Всем Добра!
СообщениеДобавлено: 12 апр 2017, 22:06
I noticed a strange thing now in the contents recorded on one of the bios of the motherboard.
I downloaded the contents of memory M_bios from the gibabyte website.
1 ° I recorded the last version of the bios in memory M_bios
2º When I went to read the contents of the memory B_bios I noticed that it was blank, there was nothing recorded there.
3rd anyway I recorded the last version of bios in this memory B_bios.
4º After recording the two memories, both being equal, there is no video on the monitor besides looping on the diagnostic card.
I'm going to carry out a voltage measurement on all the pins of the two memories, then I put the result, okay.
СообщениеДобавлено: 13 апр 2017, 16:26
For correct operation, one BIOS stick is sufficient.
1. You can take both.
2. On one of them write a bios from the manufacturer's website. And install it in place of M.
3. Backup Bios (B_bios)It is not necessary to install for motherboard. You can epty place b_bios.
Good luck~
В этой теме нет новых непрочитанных сообщений. gigabyte GA-G31M-ES2C Doubts about heating in two electrolytic capacitors near memory
в форуме Gigabyte
eletmoraes
13 апр 2017, 18:24
practicezerg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte ga-g31m-es2c
в форуме Gigabyte
incomum
1400
13 мар 2019, 13:42
bojfriend Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte GA -G31M-ES2C Ошибка CE
в форуме Gigabyte
unknown99
1942
27 мар 2019, 22:25
BMA Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GA-G31M-ES2C (Ресет вместо PowerOff)
в форуме Gigabyte
fraud72
1754
01 июн 2018, 09:56
jetbalance Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
