Заголовок сообщения: Sony Vaio (SVE14A15(board code MBX-273)) auto shut down
Добавлено: 17 апр 2017, 08:27
Зарегистрирован: 17 апр 2017, 07:09 Наличности на руках: 2.00 Сообщения: 1 Откуда: Indonesia
Hello guys, I got the SVE14A15 with Discrete ATi GPU. with MBX-273 printed on the mainboard. The previous problem was the GPU Chip pad is corrosion then I decided to put off the GPU Chip. After that the laptop always running with the Fan always on full speed RPM and then auto shutdown within +- 60 second.
I found that the problem is in the ME Region. Please help me with the Clear ME Region.
Thank you very much.
and555
Заголовок сообщения: Re: Sony Vaio (SVE14A15(board code MBX-273)) auto shut down [РЕШЕНО]
Добавлено: 20 апр 2017, 16:40
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09 Сообщения: 285 Откуда: Indonesia
I don't think it's ME problem, it's overheat problem, I usually add a copper plate between the GPU to the heatsink. But, if You want clear ME, try below:
MBX-273_ClearME(v8.1.0.1248).bin.7z
Сейчас этот форум просматривают: deftore и гости: 6
