Текущее время: 28 мар 2024, 16:59
notemaster
Заголовок сообщения: dv6-6150ew (pmh-41-ab6200-e00g) I can not boot from hard drive Добавлено: 23 окт 2017, 16:03 |
Зарегистрирован: 10 янв 2014, 01:59 Наличности на руках: -3.85
Сообщения: 279 Откуда: Kraków
hello, i have problem with hard drive, on bios the laptop dispaly command that there is no hard drive, when i started os from pendrive i can see the partition on hard drive and also files, but i can not boot system from hard drive, i flashed the bios, and the same situation, replaced the connector hard drive with mb and nothing, in replaced the notrh brigde SLJ4P - HM65 the same situation, what can i do else ?
