Текущее время: 29 мар 2024, 15:27
 Заголовок сообщения: Searching for - Dell Vostro 470/XPS 8500 BIOS dump
СообщениеДобавлено: 19 ноя 2015, 00:22
Hi, I'm searching for Dell Vostro 470/XPS 8500 BIOS dump (both computers have the same motherboard).
Maybe someone has acces to one of these computers?
I need full 4MB file (upgrades from Dell site doesn't work :( )
 Заголовок сообщения: Re: Searching for - Dell Vostro 470/XPS 8500 BIOS dump
СообщениеДобавлено: 27 янв 2016, 20:37
Hello. Are your problem still actual?
СообщениеДобавлено: 24 фев 2016, 20:14
Hello
If you need a dump.
viewtopic.php?f=277&t=40273&p=312687#p312687
Regards
СообщениеДобавлено: 17 окт 2017, 22:59
Yes, still actual
siwyqq писал(а):
Hello
If you need a dump.
Regards
I can't download it, because I don't have 15 posts on forum.
I tried to reflash BIOS with file below - can anyone check if its the same file that siwyqq gave link to?
Or can anyone sand it to me? atetus @ interia . pl
СообщениеДобавлено: 21 окт 2017, 15:34
Check mail.
СообщениеДобавлено: 21 окт 2017, 21:22
Thank You very much ;)
Later I will post the results - but it will take some weeks or months (I don't have much time)
СообщениеДобавлено: 07 ноя 2017, 19:38
Something is working - BIOS shows XPS 8500 model with diffrent service tag (previously was Vostro 470) would it have influence of system working, drivers etc?
СообщениеДобавлено: 07 ноя 2017, 19:54
If it boots up and all devices are visible in the OS, I wouldn't worry too much about it.
СообщениеДобавлено: 07 ноя 2017, 20:45
Ok, so I have to install system now - I haven't time for it today.
Thanks for Your reply :)
СообщениеДобавлено: 17 дек 2017, 22:54
Pls help with Dell Vostro 460/XPS 8300 BIOS dump.
СообщениеДобавлено: 21 фев 2018, 14:27
Look here: viewtopic.php?f=277&t=65239
СообщениеДобавлено: 21 фев 2018, 21:53
I send You that file on e-mail ;)
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Searching bios DELL E4310 LA-5691p dump U34
в форуме Dell
djkarol
17 мар 2016, 21:09
djkarol Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. searching for dvr dump td-2304ss-c
belmmahi
07 мар 2019, 21:09
fobos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. LG 17U70N-J (SJ17C) Searching Bios for this model
в форуме Поиск BIOS
josebml
25 сен 2023, 12:34
josebml Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS TUF Dash F15 FX517ZM searching for bios
в форуме Поиск BIOS
hunmike000
12 окт 2023, 00:26
Kaizeroff123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Jovy System RE-8500
в форуме Оборудование для ремонта | Repair Equipment
oldabrikos
4116
Вчера, 21:34
hynt Перейти к последнему сообщению
Сейчас этот форум просматривают: soryu и гости: 1
