Текущее время: 28 мар 2024, 19:08
Страница 1 из 1 [ Сообщений: 2 ] |
pall-dnb
Заголовок сообщения: слетела прошивка AK8287_AHD&16CH Добавлено: 22 сен 2020, 22:57 |
Сообщения: 7 Откуда: Rostov
Приветствую! На китайском dvr 81AHD слетела прошивка,на экране постоянно цветной матрас. прошивок в сети не нашел. Флешка W25Q128. Может есть у кого прошивка
плата
log
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.22 21:22:22 =~=~=~=~=~=~=~=~=~=~=~= 0GM8287 SYSTEM go.................DR 1.6 512MB
MP SPI-NOR Bootstrap v0.1
SPI020 Revision:0x10001
SPI flash ID code:ef 40 18
Boot image offset: 0x10000. size: 0x50000. Booting Image .....
U-Boot 2013.01 (Jul 15 2014 - 15:53:21)
DRAM: 512 MiB ROM CODE has enable I cache SPI mode SF: Got idcodes 00000000: ef 40 18 00 .@..
SF: Detected W25Q128 with page size 64 KiB, total 16 MiB flash is 3byte mode
*** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial
------------------------------- ID:82870003 AC: 396 HC: 297 P1:1188 P4: 768 C6: 792 DR:1584 J: 297 H1: 396 H2: 396 ------------------------------- Net: GMAC set RMII mode reset PHY eth0 Warning: eth0 MAC addresses don't match: Address in SROM is 3d:73:71:75:61:73 Address in environment is 00:42:70:00:30:22
Hit any key to stop autoboot: 3 0GM8287 SYSTEM go.................DR 1.6 512MB
Hit any key to stop autoboot: 3 2 1 0 start hdmi polling thread. sli-hdmi is in 1920x1080 RGBI2C_IP1_init APB freq = 49500000 I2C_IP1_init: speed: 100000, div = 244 Please plug-in the HDMI cable, otherwise the system may keep wating the connection.... tmp = 21 SF: Got idcodes 00000000: ef 40 18 00 .@..
## Booting kernel from Legacy Image at 02000000 ... Image Name: gm828x Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2849696 Bytes = 2.7 MiB Load Address: 02000000 Entry Point: 02000040 Verifying Checksum ... OK XIP Kernel Image ... OK OK : mem=512M gmmem=432M console=ttyS0,115200 user_debug=31 init=/squashfs_init root=/dev/mtdblock2 rootfstype=squashfs
Starting kernel ...
Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 Linux version 3.3.0 (john@john) (gcc version 4.4.0 20100318 (experimental) (Buildroot 2012.02) ) #46 PREEMPT Wed Jun 18 16:21:01 CST 2014 CPU: FA6 [66056262] revision 2 (ARMv5TE), cr=0000397f CPU VIPT aliasing data cache, unknown instruction cache Machine: Grain-Media GM828x series Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: mem=512M gmmem=432M console=ttyS0,115200 user_debug=31 init=/squashfs_init root=/dev/mtdblock2 rootfstype=squashfs PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 513920k/513920k available, 10368k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xa0800000 - 0xff000000 (1512 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) modules : 0x7f000000 - 0x80000000 ( 16 MB) .text : 0x80008000 - 0x805360e8 (5305 kB) .init : 0x80537000 - 0x80553000 ( 112 kB) .data : 0x80554000 - 0x805765e0 ( 138 kB) .bss : 0x80576604 - 0x805b0624 ( 233 kB) NR_IRQS:96 Timer use APB0 clock gm_jiffies_init, system HZ: 100, pClk: 49500000 console [ttyS0] enabled Calibrating delay loop... 789.70 BogoMIPS (lpj=3948544) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok Setting up static identity map for 0x3d5b70 - 0x3d5bb8 devtmpfs: initialized FMEM: 110592 pages(0x1b000000 bytes) from bank0 are reserved for Frammap. FMEM: Logical memory ends up at 0xa0000000, init_mm:0x80004000(0x4000), PAGE_OFFSET:0x80000000(0x0), FMEM: FA726 Test and Debug Register: 0x0 NET: Registered protocol family 16 PMU: Mapped at 0xfe000000 IC: GM8287, version: 0x3 @@@@@@@@@@@@@@@@@@@@@@@@ CHIP Version: unknown! @@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@ CHIP Version: unknown! @@@@@@@@@@@@@@@@@@@@@@@@ iotable: VA: 0xfe000000, PA: 0x99000000, Length: 4096 iotable: VA: 0xfe001000, PA: 0x98300000, Length: 4096 iotable: VA: 0xfe002000, PA: 0x98400000, Length: 4096 iotable: VA: 0xfe003000, PA: 0x98500000, Length: 4096 iotable: VA: 0xfe004000, PA: 0x98800000, Length: 4096 iotable: VA: 0xfe005000, PA: 0x99100000, Length: 4096 iotable: VA: 0xfe006000, PA: 0x96000000, Length: 4096 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource fttmr010:1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Video Timer(timer3) Max 86000ms in 0xfdbcaa40 HZ. ftdmac020 ftdmac020.0: DMA engine driver: irq 1, mapped at 0xa0804000 squashfs: version 4.0 (2009/01/31) Phillip Lougher JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 1003 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) gpiochip_add: registered GPIOs 0 to 31 on device: ftgpio010.0 probe ftgpio010.0 OK, at 0xa0862000 gpiochip_add: registered GPIOs 32 to 63 on device: ftgpio010.1 probe ftgpio010.1 OK, at 0xa0864000 Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled serial8250: ttyS0 at I/O 0xfe001000 (irq = 9) is a 16550A serial8250: ttyS1 at I/O 0xfe002000 (irq = 10) is a 16550A brd: module loaded loop: module loaded FTSATA100_AHCI driver version 0.14 GM SATAPHY clock source : SATA0==SATA1, SATA1==PLL GM SATAPHY Clock = 30 MHz GM SATA0 config iSATA PHY setting GM SATA0 PHY program i2c register offset 0x07, value=0x09 GM SATA0 PHY program i2c register offset 0x19, value=0x0c GM SATA0 PHY program i2c register offset 0x35, value=0x10 GM SATA0 PHY program i2c register offset 0x36, value=0x80 GM SATA1 config iSATA PHY setting GM SATA1 PHY program i2c register offset 0x07, value=0x09 GM SATA1 PHY program i2c register offset 0x19, value=0x0c GM SATA1 PHY program i2c register offset 0x35, value=0x10 GM SATA1 PHY program i2c register offset 0x36, value=0x80 ahci ftsata100.0: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ahci ftsata100.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi0 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0x93200000-0x93200fff] port 0x100 irq 28 ahci ftsata100.1: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ata1: SATA link down (SStatus 0 SControl 310) ahci ftsata100.1: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.1: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi1 : ahci_platform ata2: SATA max UDMA/133 mmio [mem 0x93300000-0x93300fff] port 0x100 irq 40 Not for NAND pin mux SPI020 init ftspi020 ftspi020.0: Faraday FTSPI020 Controller at 0x80300000(0xa086e000) irq 92. spi spi0.0: setup: bpw 8 mode 0 CLK div field set 2 ERASE SECTOR 64K SPI_FLASH spi0.0: w25q128bv (16384 Kbytes) Creating 10 MTD partitions on "nor-flash": 0x000000010000-0x000000060000 : "UBOOT" 0x000000060000-0x000000400000 : "LINUX" 0x000000400000-0x000000700000 : "FS" 0x000000700000-0x000000800000 : "MTD" 0x000000800000-0x000000ce0000 : "USER" 0x000000ce0000-0x000000e60000 : "WEB" 0x000000e60000-0x000000f80000 : "LOGO" 0x000000f80000-0x000000fe0000 : "CUSTOM" 0x000000fe0000-0x000001000000 : "AKP2P" 0x000000000000-0x000001000000 : "ALL" Probe FTSPI020 SPI Controller at 0x80300000 (irq 92) ftgmac100: Loading version 0.1 ... ata2: SATA link down (SStatus 0 SControl 310) ftgmac100-0-mdio: probed ftgmac100-0 ftgmac100-0.0: eth0: 1 tx queue used (max: 2) ftgmac100-0 ftgmac100-0.0: eth0: 1 rx queue used (max: 1) ftgmac100-0 ftgmac100-0.0: eth0: irq 3, mapped at a0870000 ftgmac100-0 ftgmac100-0.0: eth0: generated random MAC address 82:00:1c:c7:37:25 PPP generic driver version 2.4.2 PPP BSD Compression module registered PPP Deflate Compression module registered NET: Registered protocol family 24 usbcore: registered new interface driver ath9k_htc ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver FOTG2XX Controller Initialization Enter Device A Drive Vbus because of ID pin shows Device A fotg210 fotg210.0: FOTG2XX fotg210 fotg210.0: new USB bus registered, assigned bus number 1 fotg210 fotg210.0: irq 93, io mem 0x93000000 fotg210 fotg210.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected FOTG2XX Controller Initialization Enter Device A Drive Vbus because of ID pin shows Device A fotg210 fotg210.1: FOTG2XX fotg210 fotg210.1: new USB bus registered, assigned bus number 2 fotg210 fotg210.1: irq 94, io mem 0x93100000 fotg210 fotg210.1: USB 2.0 started, EHCI 1.00 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected usbcore: registered new interface driver cdc_acm cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters usbcore: registered new interface driver cdc_wdm Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice i2c /dev entries driver ftiic010 ftiic010.0: irq 18, mapped at a0876000 ftiic010 ftiic010.1: irq 53, mapped at a0878000 ftiic010 ftiic010.2: irq 50, mapped at a087a000 usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered NET: Registered protocol family 17 lib80211: common routines for IEEE802.11 drivers RTC-PT7C4307 init...OK List of all partitions: 1f00 320 mtdblock0 (driver?) 1f01 3712 mtdblock1 (driver?) 1f02 3072 mtdblock2 (driver?) 1f03 1024 mtdblock3 (driver?) 1f04 4992 mtdblock4 (driver?) 1f05 1536 mtdblock5 (driver?) 1f06 1152 mtdblock6 (driver?) 1f07 384 mtdblock7 (driver?) 1f08 128 mtdblock8 (driver?) 1f09 16384 mtdblock9 (driver?) No filesystem could mount root, tried: squashfs Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
Дамп
