Текущее время: 29 мар 2024, 02:57
Slavikus
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 05 окт 2012, 00:10 |
Зарегистрирован: 01 апр 2011, 14:14 Наличности на руках: 3,807.02
Mobimas писал(а): В поисках Richtek RT8202 обнаружилось сходство с UP6111AQDD . Последняя стоит в Acer Aspire One (ZG8). Вложение: RT8202_1.jpg Такая же распиновка UP6128A Вложение: uP6128A_1.jpg Описание функций
1. Wide Input Voltage Range 2V ~ 26V 2. Wide Output Voltage Range 0.75V ~ 5.5V, 1.0% Initial Accuracy 3. Constant On Time PWM : Quasi Constant Switching Frequency; Adjustable Frequency from 200kHz to500kHz; Ultra Fast Transient Response 4. Integrated Bootstrap Diode 5. Integrated MOSFET Drivers with Shoot-Through Protection 6. Configurable Forced Continuous Current Mode or Power Saving Mode 7. Lossless, Programmable Overcurrent Protection Use Low-Side MOSFET RDS(ON) 8. Internal Soft Start 9. Over Voltage and Under Voltage Protection 10. Power OK Indication 11. WQFN4x4 - 16L, WQFN3x3 - 16L, VQFN3.5X3.5 - 14L, or TSSOP - 14L Packages 12. RoHS Compliant and 100% Lead Free 產品特性 1. The uP6128A/B is a high performance synchronous-rectified buck controller specifically designed for POL voltage regulation in notebook PC application. The controller operates with 5V bias voltage and converts 2V~26V input voltage to 0.75V~5.5V output voltage. 2. The uP6128A/B adopts constant-on-time PWM scheme that features easy-to-use, low external component count, fast transient response and quasi constant frequency operation over the operation range. Selectable Forced Continuous Conduction Mode (FCCM) or Power Saving Mode (PSM) enables the flexibility for low noise operation or high efficiency conversion over wide output current range. 3. Lossless current sensing by RDS(ON) of lower switch achieves programmable over current protection. Other features include internal soft start, integrated bootstrap diode and thermal shutdown. The uP6128A is available in WQFN3x3 -16L and WQFN4x4-16L packages. 4. The uP6128B is available in VQFN3.5x3.5- 14L and TSSOP- 14L packages. 產品應用 1. Power Supplies for Microprocessors or Subsystem Power Supplies 2. Cable Modems, Set Top Boxes, and DSL Modems 3. Industrial Power Supplies; General Purpose Supplies 4. 2V to 26V Input DC-DC Regulators 5. Low-Voltage Distributed Power Supplies
Еще аналог G5602R41U применяемый в схеме от Quanta HK5 Вложение: G5602R41U.7z
Slavikus
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 10 окт 2012, 10:14 |
Ciber SLasH писал(а): MAX8778=MAX17020, ISL6236, ISL6236A, PM6686, RT8206A, SN0608098 - взаимозаменяемы между собой. HP DV6940er - Quanta AT3 Rev. F - стоит ISL6236 (по схеме MAX8778). Еще аналог SN0806081 RHBR QFN32 5x5 применяется в Compal LA-5911P Вложение: SN0806081RHBR_QFN32_5x5.rar
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 10 окт 2012, 13:50 |
Зарегистрирован: 10 май 2012, 04:30 Наличности на руках: 697.52
Сообщения: 301 Откуда: Таганрог
Slavikus писал(а): Ciber SLasH писал(а): MAX8778=MAX17020, ISL6236, ISL6236A, PM6686, RT8206A, SN0608098 - взаимозаменяемы между собой. HP DV6940er - Quanta AT3 Rev. F - стоит ISL6236 (по схеме MAX8778). Еще аналог SN0806081 RHBR QFN32 5x5 применяется в Compal LA-5911P... Ну, вот и свалили всё в одну кучу... Надо всё-таки внести какую-то ясность. Во-первых, о терминологии. Понятия "аналог" и "взаимозаменяемо" не есть одно и то же. Аналог подразумевает полное функциональное и выводное совпадение (так сказать, но-га-вно-гу). Например, разные фирмы могут выпускать один и тот же прибор, но под разными названиями. Взаимозаменяемость - более широкое понятие. Например, некоторые приборы почти совпадают по цоколёвке (скажем, отличаются одним из выводов функционально), но могут использоваться для взаимной замены там, где этот вывод не используется. Хотелось бы точности - чтобы было ясно, о чём идёт речь в каждом посте этой темы: где о взаимозаменяемости, а где приводятся аналоги. И там, где приборы не являются полными аналогами, нужно указывать: "взаимозаменяемо там-то и там-то". Отсутствие подобной точности вносит некоторую путаницу. Это, так сказать, умные рассуждения. Теперь конкретно по вышеприведённому списку. Не претендую на абсолютную точность, но хочу разграничить список на аналоги, и упомянуть о взаимозаменяемости внутри него. Аналогами согласно даташитов (а, где они не доступны - согласно анализу схем включения на конкретных платформах) являются: 1. TPS51427(A) = SN0806081 2. MAX8778=MAX17101=MAX17020=PM6686=SN608098=ISL6236(A)Замечу, что "из-за наличия отсутствия" даташитов на SN608098, SN0806081 анализ их включения проводился по схемам MBX-215 и LA-5911P, а для MAX8778 (из даташита на MAX17020) - «The MAX17020 is a pin-for-pin replacement of the MAX8778». Теперь о мелочах. Главное отличие между 1, 2 строчками - вывод 20. Для первой - он "NC" (не используется), для второй - это вывод SECFB (CP_FB), который мониторит 14-вольтовый выход "Charge Pump", и не даёт там упасть напряжению ниже порога. Соответственно, в схемах, где данная м\с не формирует выходные 14 вольт , обе строчки взаимозаменяемы. ISL6237 взаимозаменяема с первой строчкой там, где выход LDO 3.3V (вывод 5) в схеме не используется (в данной м\с он "NC"). RT8206А,B не являются аналогами для обеих строк, но могут использоваться для взаимозаменяемости с ними в конкретных случаях. RT8206А функционально ближе ко второй строке, но в ней, в отличие от всей линейки, не используются выводы 5, 8 (оба "NC"). RT8206B функционально самая кастрированная – в ней не используются все три вывода 5, 8, 20. Для удобства данные о различающихся выводах сведены в Таблицу: Вложение: Таблица.jpg Можно предполагать, что с соответствующей доработкой все эти м\с могут быть использованы для взаимной замены (причём, в тех схемах, где выв.7 LDO фиксированный 5 вольт, а выв. 5 (LDO 3.3в) не используется, могут работать и RT8206A,B).
Последний раз редактировалось тагансити 10 окт 2012, 19:27, всего редактировалось 1 раз.
Slavikus
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 10 окт 2012, 15:01 |
Ну конечно проведеный ШИМ нельзя без даташита от производителя назвать полным аналогом той или иной микросхемы, и все конечно зависит в какой схеме эти микросхемы применяются и какие выводы используются, а в кучу свалены, так сказать для дальнейшей отбраковки зЁрен от плевел, методом подробного сравнения схем и даташитов, что с помощью, вами же приведенной, таблицы и продемонстрировано. За взаимозаменяемость ШИМов питания всех рас и народов
Ciber SLasH
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 09 ноя 2012, 19:00 |
Модератор |
Зарегистрирован: 29 окт 2010, 00:27 Наличности на руках: 1,820.42
Сообщения: 7756 Откуда: Питер
P2806, G5934 - аналоги (спасибо siberian)
Slavikus
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 15 ноя 2012, 19:24 |
Взаимозаменяемы только отличаются мощностью в разы,то есть не для каждой схемы замена корректна, хотя для ноутов прокатит. Вложение: OZ8111.jpg OZ8116 Вложение: OZ8116.jpg
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 17 ноя 2012, 06:09 |
Несколько слов о взаимозаменяемости SC475A и НЕвзаимозаменяемости SC471 и SC471A. Указанные м\с имеют идентичную распиновку, и выходные полевые ключи с открытым истоком D0 (D1), управляемые входами G0 (G1). В схемах включения эти ключи используются для регулирования номинала выходного напряжения: Вложение: sc471(A) .jpg Причём, для SC471 входы G0,G1 - прямые, а для SC471A - инверсные (в SC471 ключи D0,D1 открываются "единицей", а в SC471A - нулём), SC475A имеет только один канал - G0,D0 с инверсным управлением. Соответственно, SC475A может быть с успехом заменена на SC471A в любой схеме (нужно только следить, чтобы на плате неиспользуемый вывод 7 SC475A не был бы случайно подключён куда-либо , ибо для SC471A это - выход D1). Совершенно понятно, что SC471 и SC471A - не взаимозаменяемы без инверсии входных сигналов G0,G1. Впрочем, для мьсе, знающих толк в извращениях, это не помеха - при желании, можно впихнуть по входам G0,G1 два N-полевика с пуллапами на стоках...
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 30 ноя 2012, 08:58 |
jak_root писал(а): BP1IG <==> BP9ZA <==> BP0QA SY8033BDBC_DFN10_3X3 Список можно расширить: SY8033BDBC_DFN10_3X3 BP0QA BP1BE BP1GGBP1IG BP9ZA Не думаю, что этим список исчерпывается... Вложение: SY8033BDBC_LA-6881P.jpg Дополнение взято со страниц этого же и соседнего форумов.
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 26 дек 2012, 16:35 |
SashaZmei писал(а): PM6686 успешно заменен на TPS51427 Сначала внимательно читаем то, что уже написано, потом думаем, будет ли полезна информация, и нужно ли писАть...
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 20 янв 2013, 16:17 |
galexey писал(а): tps51620 и tps51621 аналоги? На схеме LA-5082P нарисован tps51620, на плате стоит tps51621. Что-то непонятно, где Вы смотрите... К Вам плата не из пионерсервиса пришла? Даже из простого сравнения схем включения - цоколёвка ну, ни разу не совпадает!
Zet
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 28 янв 2013, 18:17 |
Зарегистрирован: 13 янв 2012, 21:28 Наличности на руках: 252.95
Сообщения: 496 Откуда: SPb
RsM писал(а): ......... но мне лень рисовать Мне тоже , я что делать. Подумалось - может сообща.
pipkata
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 30 янв 2013, 11:59 |
Зарегистрирован: 05 дек 2010, 18:31 Наличности на руках: 142.53
Сообщения: 31 Откуда: Bulgaria
Ciber SLasH писал(а): MAX17415 меняется на MAX17015 (информация от VolosKR) Asus G60JX MAX17415 меняется на MAX17015 тоже проверил. Работает нормально.
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 31 янв 2013, 01:33 |
Во многих китайских планшетах и нетбуках попадается простейший ШИМ преобразователь - восьминогая планарка в самом простом корпусе SOP-8 с маркировкой 2952 или 2952a. Вложение: AP2952A_App.jpg Это чудо - AP2952A: Вложение: AP2952A.RAR имеет аналог - FT484: Вложение: FT484.RAR Есть и второй - MP1410, но нужно учитывать, что он - без софтстарта (выв. 8 не используется), и имеет немного другие номиналы в обвязке (см. даташит). Вложение: MP1410.RAR
siberian
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 10 мар 2013, 09:24 |
Serrj писал(а): MB39A126 => MB39A129... НО !!! За всю ночь, батарею зарядил только на 3% в (Win) !!!! Разве это можно считать удачной заменой?
тагансити
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 27 апр 2013, 17:16 |
Dwit писал(а): На что можно поменять ISL6265C и TPS51123A Осмелюсь спросить - Вы эту тему-то читали? Простите, но это - неуважение к тем, кто делится (в т. ч. с Вами) своими знаниями, и тратит время на написание информативных постов - Вы же, даже их не читая, задаёте вопрос, на который ответ давным-давно дан... Конкретно - о заменяемости TPS51123A есть инфа как минимум в двух постах этой темы. Лень читать или воспользоваться поиском???
siberian
Заголовок сообщения: Re: Взаимозаменяемость ШИМов питания Добавлено: 19 июн 2013, 11:44 |
RsM писал(а): RT8205L=TPS51125 Ни разу не равно! Может в какой-то конкретной схеме...
