Здравствуйте, ищу дамп spi flash для роутера Belkin AC1900 DB (f9k1124v1).
Флешка 25l12835f .
Роутер при включении загружается в режиме восстановления и просит прошивку. Прошивку с офсайта не принимает, пишет Binary is error, please choose correct one. (may be pid is not correct).
Подпаялся к uart на плате. Вот лог, который ясно дает понять что прошивка битая:
BBoooottiinng.
DRAM Type: DDR3
DRAM frequency: 580MHz
DRAM Size = 128 MB
@ chip__no chip__id mfr___id dev___id cap___id size_sft dev_size chipSize
@ 0000000h 0c22018h 00000c2h 0000020h 0000018h 0000000h 0000018h 1000000h
@ blk_size blk__cnt sec_size sec__cnt pageSize page_cnt chip_clk chipName
@ 0010000h 0000100h 0001000h 0001000h 0000100h 0000010h 0000048h MX25L12805D
---Realtek RTL8198C boot code at 2016.03.25-21:45+0800 v1.5g (1000MHz) [C0 running][C1 sleep]
Done!
DEBUG_INF: Index Name Offset Length Real_Offs Real_Size
DEBUG_INF: 0 boot 0 20000 0 20000
DEBUG_INF: 1 cal-data 20000 10000 20000 10000
DEBUG_INF: 2 data-psi 30000 10000 30000 10000
DEBUG_INF: 3 data-voatile 40000 10000 40000 10000
DEBUG_INF: 4 nvram 50000 10000 50000 10000
DEBUG_INF: 5 nvram-bak 60000 10000 60000 10000
DEBUG_INF: 6 kernel 70000 200000 70000 200000
DEBUG_INF: 7 rootfs 270000 b00000 270000 b00000
DEBUG_INF: 8 reserved d70000 290000 d70000 290000
SC LED BLINK INIT.
Start to Clear Memory from 8008a5e4 to 88000000
Done.
Sercomm Boot Version 1.0.1.0
Entering Firmware : Everything is OK.
no sys signature at 00010000!
no sys signature at 00020000!
no sys signature at 00030000!
no sys signature at 00021000!
no sys signature at 00022000!
no sys signature at 00023000!
no sys signature at 00024000!
no sys signature at 00025000!
no sys signature at 00026000!
no sys signature at 00027000!
no sys signature at 00028000!
no sys signature at 00029000!
no sys signature at 0002A000!
no sys signature at 0002B000!
no sys signature at 0002C000!
no sys signature at 0002D000!
no sys signature at 0002E000!
no sys signature at 0002F000!
no sys signature at 00031000!
no sys signature at 00032000!
no sys signature at 00033000!
no sys signature at 00034000!
no sys signature at 00035000!
no sys signature at 00036000!
no sys signature at 00037000!
no sys signature at 00038000!
no sys signature at 00039000!
no sys signature at 0003A000!
no sys signature at 0003B000!
no sys signature at 0003C000!
no sys signature at 0003D000!
no sys signature at 0003E000!
no sys signature at 0003F000!
no sys signature at 00040000!
no sys signature at 00041000!
no sys signature at 00042000!
no sys signature at 00043000!
no sys signature at 00044000!
no sys signature at 00045000!
no sys signature at 00046000!
no sys signature at 00047000!
no sys signature at 00048000!
no sys signature at 00049000!
no sys signature at 0004A000!
no sys signature at 0004B000!
no sys signature at 0004C000!
no sys signature at 0004D000!
no sys signature at 0004E000!
no sys signature at 0004F000!
no sys signature at 00050000!
no sys signature at 00051000!
no sys signature at 00052000!
no sys signature at 00053000!
no sys signature at 00054000!
no sys signature at 00055000!
no sys signature at 00056000!
no sys signature at 00057000!
no sys signature at 00058000!
no sys signature at 00059000!
no sys signature at 0005A000!
no sys signature at 0005B000!
no sys signature at 0005C000!
no sys signature at 0005D000!
no sys signature at 0005E000!
no sys signature at 0005F000!
no sys signature at 00060000!
no sys signature at 00061000!
no sys signature at 00062000!
no sys signature at 00063000!
no sys signature at 00064000!
no sys signature at 00065000!
no sys signature at 00066000!
no sys signature at 00067000!
no sys signature at 00068000!
no sys signature at 00069000!
no sys signature at 0006A000!
no sys signature at 0006B000!
no sys signature at 0006C000!
no sys signature at 0006D000!
no sys signature at 0006E000!
no sys signature at 0006F000!
no sys signature at 00070000!
no sys signature at 00071000!
no sys signature at 00072000!
no sys signature at 00073000!
no sys signature at 00074000!
no sys signature at 00075000!
no sys signature at 00076000!
no sys signature at 00077000!
no sys signature at 00078000!
no sys signature at 00079000!
no sys signature at 0007A000!
no sys signature at 0007B000!
no sys signature at 0007C000!
no sys signature at 0007D000!
no sys signature at 0007E000!
no sys signature at 0007F000!
no sys signature at 00080000!
no sys signature at 00081000!
no sys signature at 00082000!
no sys signature at 00083000!
no sys signature at 00084000!
no sys signature at 00085000!
no sys signature at 00086000!
no sys signature at 00087000!
no sys signature at 00088000!
no sys signature at 00089000!
no sys signature at 0008A000!
no sys signature at 0008B000!
no sys signature at 0008C000!
no sys signature at 0008D000!
no sys signature at 0008E000!
no sys signature at 0008F000!
no sys signature at 00090000!
no sys signature at 00091000!
no sys signature at 00092000!
no sys signature at 00093000!
no sys signature at 00094000!
no sys signature at 00095000!
no sys signature at 00096000!
no sys signature at 00097000!
no sys signature at 00098000!
no sys signature at 00099000!
no sys signature at 0009A000!
no sys signature at 0009B000!
no sys signature at 0009C000!
no sys signature at 0009D000!
no sys signature at 0009E000!
no sys signature at 0009F000!
no sys signature at 000A0000!
no sys signature at 000A1000!
no sys signature at 000A2000!
no sys signature at 000A3000!
no sys signature at 000A4000!
no sys signature at 000A5000!
no sys signature at 000A6000!
no sys signature at 000A7000!
no sys signature at 000A8000!
no sys signature at 000A9000!
no sys signature at 000AA000!
no sys signature at 000AB000!
no sys signature at 000AC000!
no sys signature at 000AD000!
no sys signature at 000AE000!
no sys signature at 000AF000!
no sys signature at 000B0000!
no sys signature at 000B1000!
no sys signature at 000B2000!
no sys signature at 000B3000!
no sys signature at 000B4000!
no sys signature at 000B5000!
no sys signature at 000B6000!
no sys signature at 000B7000!
no sys signature at 000B8000!
no sys signature at 000B9000!
no sys signature at 000BA000!
no sys signature at 000BB000!
no sys signature at 000BC000!
no sys signature at 000BD000!
no sys signature at 000BE000!
no sys signature at 000BF000!
no sys signature at 000C0000!
no sys signature at 000C1000!
no sys signature at 000C2000!
no sys signature at 000C3000!
no sys signature at 000C4000!
no sys signature at 000C5000!
no sys signature at 000C6000!
no sys signature at 000C7000!
no sys signature at 000C8000!
no sys signature at 000C9000!
no sys signature at 000CA000!
no sys signature at 000CB000!
no sys signature at 000CC000!
no sys signature at 000CD000!
no sys signature at 000CE000!
no sys signature at 000CF000!
no sys signature at 000D0000!
no sys signature at 000D1000!
no sys signature at 000D2000!
no sys signature at 000D3000!
no sys signature at 000D4000!
no sys signature at 000D5000!
no sys signature at 000D6000!
no sys signature at 000D7000!
no sys signature at 000D8000!
no sys signature at 000D9000!
no sys signature at 000DA000!
no sys signature at 000DB000!
no sys signature at 000DC000!
no sys signature at 000DD000!
no sys signature at 000DE000!
no sys signature at 000DF000!
no sys signature at 000E0000!
no sys signature at 000E1000!
no sys signature at 000E2000!
no sys signature at 000E3000!
no sys signature at 000E4000!
no sys signature at 000E5000!
no sys signature at 000E6000!
no sys signature at 000E7000!
no sys signature at 000E8000!
no sys signature at 000E9000!
no sys signature at 000EA000!
no sys signature at 000EB000!
no sys signature at 000EC000!
no sys signature at 000ED000!
no sys signature at 000EE000!
no sys signature at 000EF000!
no sys signature at 000F0000!
no sys signature at 000F1000!
no sys signature at 000F2000!
no sys signature at 000F3000!
no sys signature at 000F4000!
no sys signature at 000F5000!
no sys signature at 000F6000!
no sys signature at 000F7000!
no sys signature at 000F8000!
no sys signature at 000F9000!
no
sys signature at 000FA000!
no sys signature at 000FB000!
no sys signature at 000FC000!
no sys signature at 000FD000!
no sys signature at 000FE000!
no sys signature at 000FF000!
no sys signature at 00100000!
return_addr 05100000, ret = 00000000
Can not find Kernel to load, go to Http Upgrade:
SC LED BLINK MODE SET 1
Лог при попытке прошится официальной прошивкой через страницу восстановления:
DEBUG_INF:************************************
DEBUG_INF:In Boot Web Uprade Mode ...
Buffer to Hold image from web: a0a00000
NVRAM restore required : YES
Unzip Buffer to Hold decompressed data: a2000000
DEBUG_INF:GET ARP REQUEST.
DEBUG_INF:DO ARP REPLY.
DEBUG_INF:TCP_SOCKET_INIT: _LISTEN.
DEBUG_INF:TCP_LISTEN:
DEBUG_INF:TCP_SYN_RCVD:
DEBUG_INF:_SYN_RVCD —> _ESTABLISHED
DEBUG_INF:HTTP METHOD: GET.
DEBUG_INF:HTTP METHOD: POST.
DEBUG_INF:checksum is <0xffffffb9>
DEBUG_INF:Checksum check fail!
DEBUG_INF:PID error !!!
DEBUG_INF:file transfer completed through net
DEBUG_INF:Check integrity of Image(image len acae35) ...
DEBUG_INF:Image CheckSum Error
DEBUG_INF:Call System Reset !
reboot.......
Если у кого есть дамп - скиньте пожалуйста, можно не бесплатно.
