| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__| ** LOADER **
** MARVELL BOARD: DHNSMR03 LE
U-Boot 1.1.1 (Jun 27 2008 - 13:41:46) USI u-boot-1.1.1-DHNSMR03/04-v128M
DRAM CS[0] base 0x00000000 size 128MB
DRAM Total size 128MB
[4096kB@ffc00000] [0kB@fa000000] ## Unknown FLASH at fa000000: Size = 0x00000000 = 0 MB
Flash: 4 MB
Addresses 20M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (20M - 16M): Done
Soc: 88F5182 A2
CPU: ARM926 (Rev 0) running @ 400Mhz
Orion 1 streaming disabled
SysClock = 200Mhz , TClock = 166Mhz
USB 0: host mode
USB 1: host mode
PCI 0: PCI Express Root Complex Interface
PCI 1: Conventional PCI, speed = 66000000
Net: egiga0 [PRIME]
Hit any key to stop autoboot: 0
Marvell>> prompt
Unknown command 'prompt' - try 'help'
Marvell>> boot
## Booting image at ffc00000 ...
Image Name: Linux-2.6.22.7
Created: 2008-09-04 23:24:49 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1572880 Bytes = 1.5 MB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
OK
## Loading Ramdisk Image at 01200000 ...
Image Name:
Created: 2008-09-06 4:20:12 UTC
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 614234 Bytes = 599.8 kB
Load Address: 00000000
Entry Point: 00000000
Starting kernel ...
Uncompressing Linux....................................................................................................... done, booting the kernel.
Linux version 2.6.22.7 (soho@bsoho084.lss.emc.com) (gcc version 4.2.1) #1 Thu Sep 4 19:24:45 EDT 2008
CPU: ARM926EJ-S [41069260] revision 0 (ARMv5TEJ), cr=a0053177
Machine: Feroceon
Using UBoot passing parameters structure
Memory policy: ECC disabled, Data cache writeback
CPU0: D VIVT write-back cache
CPU0: I cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
CPU0: D cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets
Built 1 zonelists. Total pages: 32512
Kernel command line: console=ttyS0,115200
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB 0MB 0MB 0MB = 128MB total
Memory: 125952KB available (2944K code, 234K data, 116K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Sys Clk = 200000000, Tclk = 166666667
CPU Interface
SDRAM_CS0 ....base 00000000, size 128MB
SDRAM_CS1 ....disable
SDRAM_CS2 ....disable
SDRAM_CS3 ....disable
PEX0_MEM ....base e0000000, size 128MB
PEX0_IO ....base f2000000, size 1MB
PCI0_MEM ....base e8000000, size 128MB
PCI0_IO ....base f2100000, size 1MB
INTER_REGS ....base f1000000, size 1MB
DEVICE_CS0 ....no such
DEVICE_CS1 ....base f4000000, size 32MB
DEVICE_CS2 ....no such
DEV_BOOCS ....base ff800000, size 8MB
CRYPT_ENG ....base f0000000, size 64KB
Marvell Development Board (LSP Version 3.0.5_NAS_GDP)-- RD-88F5182-DAYTONA Soc: 88F5182 A2
Detected Tclk 166666667 and SysClk 200000000
Marvell USB EHCI Host controller #0: c12be600
Marvell USB EHCI Host controller #1: c12be400
PCI: bus0: Fast back to back transfers enabled
PCI: bus1: Fast back to back transfers enabled
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Time: orion_clocksource clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 599K
RTC registered
cesadev_init(c00117b0)
Use the XOR engines (acceleration) for enhancing the following functions:
o RAID 5 Xor calculation
o copy user to/from kernel buffers
Number of XOR engines to use: 2
NetWinder Floating Point Emulator V0.97 (double precision)
audit: initializing netlink socket (disabled)
audit(946687710.000:1): initialized
Installing knfsd (copyright (C) 1996
okir@monad.swb.de).
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 3) is a 16550A
serial8250.0: ttyS1 at MMIO 0xf1012100 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
Marvell Ethernet Driver 'mv_ethernet':
o Uncached descriptors in DRAM
o DRAM SW cache-coherency
o TCP segmentation offload enabled
o Checksum offload enabled
o Rx desc: 128
o Tx desc: 256
o Loading network interface 'eth0'
Intergrated Sata device found
scsi0 : Marvell SCSI to SATA adapter
scsi1 : Marvell SCSI to SATA adapter
scsi 0:0:0:0: Direct-Access WDC WD800JD-60LSA5 10.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
Iomega834x: Probing for flash...
Flash: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Iomega834x: Flash found at location 0xffc00000
Creating 3 MTD partitions on "Flash":
0x00000000-0x00200000 : "zImage"
0x00200000-0x00380000 : "initrd"
0x00380000-0x00400000 : "bootloader"
ehci_marvell ehci_marvell.4523: Marvell Orion EHCI
ehci_marvell ehci_marvell.4523: new USB bus registered, assigned bus number 1
ehci_marvell ehci_marvell.4523: irq 17, io base 0xf1050100
ehci_marvell ehci_marvell.4523: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci_marvell ehci_marvell.167817: Marvell Orion EHCI
ehci_marvell ehci_marvell.167817: new USB bus registered, assigned bus number 2
ehci_marvell ehci_marvell.167817: irq 12, io base 0xf10a0100
ehci_marvell ehci_marvell.167817: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
USB Universal Host Controller Interface driver v3.0
Initializing USB Mass Storage driver...
usb 2-1: new high speed USB device using ehci_marvell and address 2
usb 2-1: configuration #1 chosen from 1 choice
scsi2 : SCSI emulation for USB Mass Storage devices
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
md: raid1 personality registered for level 1
TCP cubic registered
NET: Registered protocol family 17
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
cat: can't open '/sys/block/sdb/removable': No such file or directory
mdadm: No devices to examine
cat: can't open '/sys/block///size': No such file or directory
Sys UUID is :943a239d:0ca4f876:0d6ba2db:64c12aaf
Valid Disk 1 in md0: /dev/sda1
Valid Disk 2 in md0:
USB Device node is /dev/sdb1
Checking if there is an attached EMC Imager
scsi 2:0:0:0: Direct-Access JetFlash Transcend 8GB 1100 PQ: 0 ANSI: 4
sd 2:0:0:0: [sdb] 15826944 512-byte hardware sectors (8103 MB)
sd 2:0:0:0: [sdb] Write Protect is off
sd 2:0:0:0: [sdb] Assuming drive cache: write through
sdb: sdb1
sd 2:0:0:0: [sdb] Attached SCSI removable disk
sd 2:0:0:0: Attached scsi generic sg1 type 0
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Checking for valid image in hard drives
md: md0 stopped.
md: bind<sda1>
raid1: raid set md0 active with 1 out of 2 mirrors
mdadm: /dev/md0 has been started with 1 drive (out of 2).
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
No EMC Imager Found and No valid image in hard drive.
Going in to Network Imaging Mode
eth0: link down
udhcpc (v1.8.2) started
Sending discover...
eth0: link up, full duplex, speed 100 Mbps
Sending discover...
Sending select for 192.168.0.65...
Lease of 192.168.0.65 obtained, lease time 14400
deleting routers
route: ioctl 0x890c failed: No such process
adding dns 192.168.0.1
Network_imaging Stage 1
mknod: /dev/md0: File exists
md: md3 stopped.
mdadm: stopped /dev/md3
md: md0 stopped.
md: unbind<sda1>
md: export_rdev(sda1)
mdadm: stopped /dev/md0
md: md1 stopped.
mdadm: stopped /dev/md1
md: md2 stopped.
mdadm: stopped /dev/md2
10000+0 records in
10000+0 records out
Drive name = sda, Part size = 2040254
Valid partition found
sdb is not a hard drive
Creating raid 1...
md: bind<sda1>
md: md0: raid array is not clean -- starting background reconstruction
mdadm: array /dev/md0 started.
Creating filesystem on /dev/md0...
mke2fs 1.40.2 (12-Jul-2007)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
127744 inodes, 255008 blocks
12750 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=264241152
8 block groups
32768 blocks per group, 32768 fragments per group
15968 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 26 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
Device Model- m1
Device: Socket Listening on: 2081
Mac address = 00:d0:b8:02:94:fa
Device: Sent a broadcast packet
Device: Waiting for Hello Response...
No response received
Device: Going to send a broadcast again
