Текущее время: 22 ноя 2024, 04:01
 Заголовок сообщения: nobreak enermax winparts YUP-E 1200 AOT460 mosfet transistor has been totally burned out.  [РЕШЕНО]
СообщениеДобавлено: 09 мар 2019, 20:46
I'm not finding this transistor to buy in my city. I would like to see if I can put 2 transistors in parallel from 60v / 50A to replace the AOT460 which is 60V / 85A.
For example, I put two in parallel:
gate with gate
source with source
drain with drain
Can I do it this way?
I tried to locate the circuit diagram of the UPS but I could not
 Заголовок сообщения: Re: nobreak enermax winparts YUP-E 1200 AOT460 mosfet transistor has been totally burned out.
СообщениеДобавлено: 09 мар 2019, 21:08
Bad idea because gate current from source divided between two transistors and maybe not drive it. Try find equivalent from the same brand or other, i.e. https://www.infineon.com/dgdl/irf1018ep ... da854e1891
First compare RDS(ON) and VDS.
СообщениеДобавлено: 09 мар 2019, 21:09
Посмотри по ссылке:
https://clck.ru/FKqaz
СообщениеДобавлено: 09 мар 2019, 21:27
The only component I have at disposal with me would be an IRF2807 mosfet and by the datasheet says it is 75v by 82A. Can I put it on?
СообщениеДобавлено: 09 мар 2019, 21:48
AOT460 RDS(ON) < 7.5mΩ
IRF2807 RDS(on) = 13mΩ
Not equivalent. The power dissipation will be exceeded and the transistor will burn. P=I*I*RDS(on)
Последний раз редактировалось mia 09 мар 2019, 21:51, всего редактировалось 1 раз.
СообщениеДобавлено: 09 мар 2019, 21:50
Советую придерживаться 85А лишь для проверки можете 82A
СообщениеДобавлено: 09 мар 2019, 23:48
What about the IRF3205? comparing the data sheets of both components?
СообщениеДобавлено: 10 мар 2019, 00:03
On some sites, IRF3205 is referenced as an alternative to AOT460.
СообщениеДобавлено: 11 мар 2019, 18:00
used the IRF3205 in place of the AOT460 and it worked perfectly the nobreak. Many thanks to forum colleagues
В этой теме нет новых непрочитанных сообщений. GA-F2A58M-S rev 3.2 BIOS has been reset – Please decide how to continue
в форуме Gigabyte
DimonNT
03 июн 2023, 18:09
DimonNT Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. power source MEAN WELL NES-350-5 doubt about mosfet transistor FMH07N90E
eletmoraes
30 дек 2019, 21:04
Witewut Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. msi b450-a pro max ms-7b86 rev 4.0 Over Current Have Been Detected On Your USB Device
в форуме MSI
Алексей056
3388
08 фев 2024, 23:03
Алексей056 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Вместо Mosfet soic-8 установить mosfet в другом корпусе
MVV1983
07 окт 2023, 23:22
В этой теме нет новых непрочитанных сообщений. power source Dell H220AS-00 Not initialized, totally dead
eletmoraes
14 янв 2017, 20:12
